Want to add auxiliary reverse lights that activate by switchAND shifting to reverse - Page 2 - JeepForum.com
 9Likes
post #16 of 26 Old 10-17-2019, 06:50 AM
jserna
1987 YJ Wrangler
Having the switch is the best feature!! I use it to light up an area when we are out camping or hunting. But the best use is for tailgaters and people with their brights on!!
w6pea likes this.
jserna is offline
post #17 of 26 Old 10-17-2019, 02:06 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Some are making a simple circuit overly complex for what it needs to be. There's no need for a relay, diode, etc. so long as you're using an LED aux reverse light and not an incandescent bulb which draws too much power.
The quick crudely drawn schematic shows an easy circuit that allows the aux LED reverse light to be turned on by a switch, turned on by shifting into Reverse, or turned off completely. All you need is a good quality SPDT (single pole double throw) switch and a fused 12 volt line that leads to the battery.
Ross, w6pea and Mattimus_LV like this.
Jerry Bransford is offline
post #18 of 26 Old 10-18-2019, 07:41 AM Thread Starter
Nibroc99
Nibroc99's Avatar
2003 WJ
I like this idea quite a bit - I already have the 5-prong relay though so I was honestly just gonna use that with a simple lit rocker switch sonce I already have that and it'll match the switch I already have for my front-facing light bar. Thank you for the input though as I'm sure that people looking for different solutions who stumble on this thread will definitely appreciate the alternative method!
Nibroc99 is offline
post #19 of 26 Old 10-18-2019, 07:54 AM
Mainsail
2005 WK
You know, there is a cigar lighter plug just inside the rear hatch that can power a camp light- push the plug in to turn it on, pull it out to turn it off.
Poor grammar is something up with which I shall not put.
Mainsail is offline
post #20 of 26 Old 10-18-2019, 08:18 AM Thread Starter
Nibroc99
Nibroc99's Avatar
2003 WJ
Smile
True. I'd rather have the switch though since that can be fused better as well as have it turned on only when ignition is on so as not to kill the battery by forgetting it's on.
(Also, although the wires are there in most models for a 12V outlet, the outlet is usually not there on the Laredo. I had to install an outlet myself but the wiring harness was there. Just FYI)
Nibroc99 is offline
post #21 of 26 Old 12-08-2019, 01:45 PM
w6pea
Grumpy Old Fart Marine
w6pea's Avatar
2019 WK
Interesting thread. Thanks for posting it.
"Without Trucks & Truck Driver's America Stops!"
"There's too much Blood in my Caffeine System"
."Semper Fi"
"Once A Marine Always A Marine"
2019 JGC 5.7L Hemi
w6pea is offline
post #22 of 26 Old 01-21-2020, 03:45 PM
UncleWoody
UncleWoody's Avatar
I just did this on my 03 WJ Limited. Here is the link.
https://www.jeepforum.com/forum/f310...-pods-4384099/
Mattimus_LV likes this.
"If we can really understand the problem, the answer will come out of it, because the answer is not separate from the problem"
UncleWoody is offline
post #23 of 26 Old 01-22-2020, 10:01 AM Thread Starter
Nibroc99
Nibroc99's Avatar
2003 WJ
Thank you so much for sharing! This is awesome!
Your life can change in an instant.
Make the most of what you have before it's gone.
~Corbin
Nibroc99 is offline
post #24 of 26 Old 01-25-2020, 06:46 AM
fishadventure
fishadventure's Avatar
I wouldn’t want extra things to plug in or pack/carry either. OP’s purpose is good imho
(I’m reading these threads to steal good ideas 🙂 )
Two “upgrades” come to mind. A sealed 5Ah 12V battery hidden in the rear panel work that only charges while running (via NO relay) could power the lights for many hours without flattening the starting battery. Second, a countdown timer with a 10A Normally Open relay on board is $4 on amazon - could be used to protect against ‘forgetting’ by setting a 15 minute run time.
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #25 of 26 Old 01-26-2020, 04:59 PM Thread Starter
Nibroc99
Nibroc99's Avatar
2003 WJ
Cool
Dude! I actually love those ideas. I didn't even consider using a countdown timer! The battery is a bit involved for my intended purpose but also not a bad idea! Cool stuff!!
~Corbin
Nibroc99 is offline
post #26 of 26 Old 01-26-2020, 05:50 PM
fishadventure
Thanks.
I’ll admit to having psychotic inventive tendencies and being a little bit of a compulsive parts-bin engineer 🙂
(at least as far as Jeeps and fishing boats are concerned)
