Uconnect 130 res replace - JeepForum.com
post #1 of 4 Old 06-01-2021, 08:25 AM Thread Starter
swift101
swift101's Avatar
2014 MK Compass
Question Uconnect 130 res replace
Hi everyone. I have a 14 compass latitude. Been thinking abt replacing the dang thing alot. its just getting my nerves. Is there a wiring diagram for radio somewhere? Didn't see it in manual. Also, does Uconnect get involved with the starting, alarm, etc..? Just wanna get my ducks in a roll before I do anything. Lets just say for haha's I replace it with this one>
https://www.dualav.com/dual-receiver...bt?rq=XVM279BT
I just want to make sure its a plug/play. I dont need a fancy radio. Just something better then what I got and I dont wanna spend a million dollars either.
thanks
swift101 is offline
post #2 of 4 Old 06-01-2021, 02:41 PM
cranbiz
cranbiz's Avatar
The 130 is a CANBUS radio but it doesn't have any vehicle monitoring functions. You can use any radio that you can get to fit BUT...........
If you do want the steering wheel controls and to use the existing vehicle harness, you will need either a PAC or iDatalink Maestro interface module.
02 WJ Laredo, heavily optioned but stock
12 JK, 3.5" Teraflex/Franken lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #3 of 4 Old 06-03-2021, 08:13 AM Thread Starter
swift101
swift101's Avatar
2014 MK Compass
thank you
swift101 is offline
post #4 of 4 Old 06-06-2021, 06:35 PM
KF2M
The Compass/Patriot are CANBUS low-speed. When I had a Pioneer deck I used the Maestro RR that way I did have to mess with the stock wiring. I just replaced the Pioneer (digitizer died) with a 430N in my 17 Patriot 75th (came with the 130 w/Uconnect and Sat). All I have to add is the backup cam, and have the Pat flashed to enable the camera. I will miss having the tire pressure monitor, stats, and ODBII display
KF2M is offline
