TJ Radio/Sub Relay - JeepForum.com
post #1 of 10 Old 06-21-2018, 09:39 AM Thread Starter
IL_Bow_Man
TJ Radio/Sub Relay
So my radio and stock sub are constantly coming on and off. Sometimes the sub don't power on but the radio does. Like I can be driving down the road and the radio will just shut off and turn back on. Sometimes it stays off for a day other times it works for the day. Totally random.
At first I just thought it was my radio from getting hammered by a storm. But the other day while sitting at a stop light I could hear a relay clicking on and off behind the front left speaker in the dash.
My question is 2 fold I guess. Is the picture the relay? Every time I have a chance to take the panel off and look the radio is just dead. So it is hard to find the clicking relay.
2. Does anyone know the replacement part number or aftermarket way to fix?
Thanks guys
IL_Bow_Man is offline
post #2 of 10 Old 06-21-2018, 09:40 AM Thread Starter
IL_Bow_Man
So the picture is rotated, but the picture is through the speaker opening.
post #3 of 10 Old 06-27-2018, 07:25 PM
mukluk
mukluk's Avatar
Doesn't look like a factory installed part, you may have to trace the wires to see what it goes to.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #4 of 10 Old 06-28-2018, 07:27 AM
cranbiz
cranbiz's Avatar
The part in the picture isn't a relay. It's either an impedance matching transformer or an RF choke of some sort.
Definitely not a factory part.
02 WJ Laredo, heavily optioned but stock
12 JK, 3.5" Teraflex/Franken lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #5 of 10 Old 06-29-2018, 08:41 AM Thread Starter
IL_Bow_Man
The black portion on the left of the picture is a relay. Top pulls off and it is like a standard horn relay. Most definitely a stock part of this jeep.
post #6 of 10 Old 06-29-2018, 09:50 AM
cranbiz
cranbiz's Avatar
Then it's probably a standard Bosch style relay.
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #7 of 10 Old 06-29-2018, 01:10 PM
mukluk
mukluk's Avatar
The only stock relay in the left footwell is for the lighter/accessory socket, and it's normally located about five inches forward of the location you show, on the other side of the multiple connector stack.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #8 of 10 Old 06-30-2018, 08:47 AM Thread Starter
IL_Bow_Man
This is not in the footwell. It is behind the front drivers speaker. You have have to remove the speaker to get to it. I have since heard it is referred to as the choke to reduce noise in the power for the sub.
post #9 of 10 Old 06-30-2018, 12:15 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yes, that's a choke whose job is to remove higher frequency noise.
Jerry Bransford is offline
post #10 of 10 Old 06-10-2021, 09:32 AM
TJW2002
IL_Bow_Man: Did you ever get a fix for this? I am having the same issue with a 2002 TJ.
TJW2002 is offline
