Thin marine subwoofer - Page 2 - JeepForum.com
 4Likes
post #16 of 23 Old 11-07-2019, 01:01 PM Thread Starter
Ross
Originally Posted by Wheelin98TJ View Post
Seems like a lot of the marine subwoofers are free air. I have a JL Audio sub on one boat and a Fusion sub on the other. Both are free air.
JL Audio makes this marine 8" sub in a box, but it's pricey and I'm not sure how deep the box is:
https://www.sonicelectronix.com/item...-S-GmTi-4.html
Holy flipping poop that is expensive. JL is great stuff.. it isn't much smaller than what I have now.
On Saturday I found the JL sub and cabinet in the link below at a garage sale for $35. Too big for my Jeep but it will go in my kids XJ. I did hook it up in my Jeep to make sure it worked and it sounds wonderful, esp compared to my Walmart junk.
https://www.crutchfield.com/S-j267NU...V2NzDTXx9xwFLk
01TJ33sWarn,ARBs F&R,bellyup,4.0,4.56s,5spd
99 XJ33sWinch,Electric locker up front,4.56s,4.0Auto
Ross is online now
post #17 of 23 Old 11-08-2019, 08:25 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Score!
Ross likes this.
Wheelin98TJ is offline
post #18 of 23 Old 11-08-2019, 08:42 AM Thread Starter
Ross
Score!
What if I just cut down my current box and get a shallow speaker? How do I know how small I can go?
Ross is online now
post #19 of 23 Old 11-08-2019, 08:42 AM
Wheelin98TJ
JEEP FREAK
If you really want to rock and save some space, add boat tower speakers to your roll bar.
Ross likes this.
post #20 of 23 Old 11-08-2019, 08:49 AM
Wheelin98TJ
JEEP FREAK
What if I just cut down he box I have now and get a shallow speaker? How do I know how small I can go?
If there is no hole through the magnet, you can snug the magnet up against the back of the box.
If there is a vent hole through the magnet, it needs some room. Usually around 1" or so. Some speaker manufactures provide this spec, it's called "pole vent clearance".
Ross likes this.
post #21 of 23 Old 11-08-2019, 02:00 PM Thread Starter
Ross
There was a hole in this sub so I left a couple inches. I can fit my tow strap in the area I cut off. Doesn't sound like much but every little bit helps, especially in a TJ.
By doing that I can keep my strap lower and my top should fold down better. I should still be able to pull out my strap even with the top down now.
Ross is online now
post #22 of 23 Old 11-10-2019, 10:37 AM
V8GCZJ
I would like something that could take some rain and take up less space.
Sounds like you need a custom box made unless you can find one. Either way it needs to be water proof(box). Subs come in a few types, sealed box, vented box and band pass. A band pass box may be good for a box that sees water because it's inside the box not exposed. The down side to band pass is it narrows down the range the sub puts out hence the "band pass". It allows a certain band(frequency range) through. Sub box building you need to know the specs of the speaker you will be using to formulate a box/style size. Then after it's made water proof it with some sort of coating.
https://www.crutchfield.com/S-Q0iY5V..._building.html
On a side note look around and see if you can find a Polk Audio C4 box anywhere. I installed one of these in a convertible(under the top compartment) and the sound is impressive for it's size. Of course you will have to make it waterproof but may be what you are looking for.
V8GCZJ is offline
post #23 of 23 Old 11-10-2019, 12:30 PM Thread Starter
Ross
Done. If or when the speaker in there fails again rain shallow mount.
Ross is online now
