Subwoofer in OEM console - JeepForum.com
post #1 of 16 Old 07-29-2007, 03:02 PM Thread Starter
Chris @ GATR
Chris @ GATR's Avatar
So I recently sold the Tuffy II and picked up an OEM console w/ sub from a 2004 Rubi. Since I already have an after market head unit, is there anyway to wire the sub up through my subwoofer output on the head unit? Also, is the sub pre-amplified within the console or does it need an external amp?
Got ignorance? Please see below.
Originally Posted by kd4yor View Post
Chris, I just think your having buyers remorse for all the work in your 8.8 for no added gain (over the Dana 35).
Chris @ GATR is offline
post #2 of 16 Old 07-29-2007, 03:43 PM Thread Starter
Chris @ GATR
If possible also, can someone describe the colors of the wires running to the sub/amp. I didn't have a factory sub, so I don't know how many wires there were supposed to be. Thanks.
post #3 of 16 Old 07-29-2007, 03:50 PM
EvilM0nkey
EvilM0nkey's Avatar
This is probably going to get moved, but i would imagine the sub is powered by the head unit. You would need an amplifier if that's the case
EvilM0nkey is offline
post #4 of 16 Old 07-29-2007, 04:02 PM
sryan2k1
Guest
sryan2k1 is offline
post #5 of 16 Old 07-29-2007, 04:14 PM
jeepbro's
i just took mine apart cause its not making any noise, and i believe there is an amp in the console with the speaker, because there are power and speaker wires going to it, but thats all i can help you with
2002 tj sahara 3" lift 35" km2, AtoZ rockers, 8k warn, 4.56 gears, lock-rites front and rear
jeepbro's is offline
post #6 of 16 Old 07-29-2007, 04:25 PM
arbby
2005 KJ Liberty
its an amp and sub i had one and resold it becuase I went with a tube/amp sub
|l,[___],
l---L--OlllllllO
()_) ()_)--o-)_)
Gone: 1993 YJ
arbby is offline
post #7 of 16 Old 07-29-2007, 05:10 PM Thread Starter
Chris @ GATR
Anyone know which wires go >TO> the subwoofer to give it a signal? I guess the power wires are self explanatory.
post #8 of 16 Old 07-29-2007, 06:02 PM
35sUnlimited
35sUnlimited's Avatar
I don't remember what color the wires are or what goes where, but I do remember it takes speaker level inputs from the front and rear so it does not fade with front or back. There is a also a ground, power, and remote turn on. 11 wires total.
The amp is built into the console in addition to housing the sub.
Maybe somebody has a wiring diagram from the FSM they can share. Also, there are some knowledgeable people over in the electronic forum. You may want to move the post.
04 LJ Pics:
Half top write-up:
Painted Ravines write-up:
35sUnlimited is offline
post #9 of 16 Old 07-29-2007, 06:15 PM
sryan2k1
Guest
I posted that several hours ago.
sryan2k1 is offline
post #10 of 16 Old 07-29-2007, 08:44 PM Thread Starter
Chris @ GATR
That diagram sucketh.
post #11 of 16 Old 07-29-2007, 11:09 PM
sryan2k1
Guest
Why? It's from the FSM, it shows exactly which color wires go where.
sryan2k1 is offline
post #12 of 16 Old 07-30-2007, 11:55 AM Thread Starter
Chris @ GATR
Not really. It shows no inputs or outputs. Again, a bad diagram, but a million thanks for hooking me up with it even though you didnt have to.
post #13 of 16 Old 07-30-2007, 12:30 PM
spyderbyte
https://www.jeepforum.com/forum/showthread.php?t=321354
Spyderbyte
Go with quality and cry once. Go cheap and cry often.
Originally Posted by Willys2004
Better to live with a little honor and class than die with a few extra greenbacks in your pocket.
spyderbyte is offline
post #14 of 16 Old 07-30-2007, 01:01 PM
35sUnlimited
Edit: For the 11 wire setup I spoke of.
04 LJ Pics:
Half top write-up:
post #15 of 16 Old 08-04-2007, 02:22 PM
SirGCal
RIP
SirGCal's Avatar
I do not know of any off-the-shelf way to go from RCAs back to speaker-level... Which is what the stock amp needs. And your' custom sub-functions on your head unit are only going to operate on the non-fading RCA outputs... So in short terms, you can make the sub work easily enough, but not using the head units' custom options for sub control.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
center console sub to non-subwoofer console? glook Audio, CB & Ham Radios, GPS, & Electrical 3 11-19-2009 03:37 PM
Tuffy console subwoofer MSAND1977 Audio, CB & Ham Radios, GPS, & Electrical 5 11-08-2006 09:55 PM
Console subwoofer installation help JessieDinKC Audio, CB & Ham Radios, GPS, & Electrical 16 08-30-2005 05:13 PM
will a subwoofer console fit my 98? Summit Jeep General Jeep & Off-Road Equipment 1 05-06-2004 12:58 PM
console subwoofer razor Audio, CB & Ham Radios, GPS, & Electrical 5 05-11-2003 02:41 PM
