still another need help. USB port this time - JeepForum.com
post #1 of 7 Old 05-20-2019, 11:27 PM Thread Starter
panzerjunky
Hello again
And I wanna start with a thanks for all the help yall have given me on this build . I keep askin and yall keep answerin so anyway .
This is a dumb one but I am ready to wire in my usb charging port and its only 2 pole so..... I don't want to wire it to non switched power as I don't want it lit up all the time. And I don't want to just wire to switched power if I need to charge something with the jeep off. So my other option is a SPDT switch ahead of the usb port to power it when needed . That way I can charge something while the jeep is turned off its such a small draw I doubt it will kill the batt if I forget to turn it off. What's your opinions?
panzerjunky is offline
post #2 of 7 Old 05-21-2019, 04:56 AM
JEK3
JEK3's Avatar
Sounds exactly like what I've been meaning to do for a while. For the cigarette lighter and power outlets, red/orange is the unswitched wire, red/light green is switched.
JEK3 is online now
post #3 of 7 Old 05-21-2019, 04:59 AM
Zeep
Zeep's Avatar
I installed a dual port with voltage display. Replaced the useless cig lighter.
Very pleased.
JEEP THE AR-15 OF THE AUTOMOTIVE WORLD
Zeep is offline
post #4 of 7 Old 05-21-2019, 09:51 AM Thread Starter
panzerjunky
Very pleased.
sounds like a good Idea 1 question . is it only on when the vehicle is on as I think the lighter is a switched lead?
post #5 of 7 Old 05-21-2019, 05:40 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
On your ’06 the cigar lighter/power outlet socket should get 12v power with key on & also in the acc position. That means you could have power there when the engine is off by using the acc position but would still have power off when the key is off which also is the only position that the key comes out so when the key is out you know the power is off, no extra switch to remember to turn off.
If for some reason you occasionally need power with the key out you could just move the charger over to the other power outlet temporarily.
Rubi4MyMrs is offline
post #6 of 7 Old 05-22-2019, 09:07 AM
Zeep
Zeep's Avatar
^^^ This ^^^
Zeep is offline
post #7 of 7 Old 05-22-2019, 11:31 AM
prerunner1982
1993 XJ Cherokee
I have two USB sockets wired on full time. One of which my tablet is plugged into most of the time. I even on occasion leave one of my ham radios on receiving and transmitting all day/night (it's sitting out there right now sending/receiving messages while I am at work) and don't have a problem with a dead battery in the morning or after work. You should have no issues with running your battery down.
I do agree with the LED being on all the time, luckily one of mine is under the dash out of sight and the other has a cover on it since it's not used daily but when something is plugged in I position the cover to block most of the light.
Jon
1993 XJ Sport 2 door
prerunner1982 is offline
Bangs out of low range Nicholg2286 XJ Cherokee Technical Forum 8 02-01-2019 06:05 AM
Edelbrock 4.0 aluminum head exhaust port? jeepmutiny Engines & Drivetrain 0 04-06-2018 04:05 AM
Both P0480 & P0481 Codes Displayed At Same Time m2005liberty KJ Liberty Forum 2 01-27-2018 02:19 PM
Power Port in Dash Fill Plate Bville-Bud JK Wrangler Technical Forum 2 01-01-2018 01:44 PM
Can't set the correct time on 2003 Rubi?? JimPet Audio, CB & Ham Radios, GPS, & Electrical 2 12-02-2017 04:18 AM
