Stereo Hum - JeepForum.com
post #1 of 4 Old 04-13-2019, 02:13 PM Thread Starter
aggiejon
aggiejon's Avatar
1979 CJ7
Stereo Hum
Installed a stereo, 4 channel marine amp, and 4 marine speakers, two in dash, two in rollbar pods. Works fine when engine is off. When engine is running, terrible hum/whine from all 4 speakers. Everything is grounded well, splices are soldered and taped, tried the magnets that clip over the wires but didn’t help. I’m going to try some noise filters that go inline from the stereo to the amp. If those don’t work, what should I try next?
aggiejon is offline
post #2 of 4 Old 04-13-2019, 02:50 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Make sure the antenna cable is well isolated and not touching any wires carrying power.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 4 Old 04-14-2019, 08:31 AM
V8GCZJ
Get a ground loop isolator.
V8GCZJ is offline
post #4 of 4 Old 04-15-2019, 07:59 PM
willis36
willis36's Avatar
What kind of rca are you using? Hopefully a decent twisted pair one. Are your power wires close to or run along side the rca? They should not be. Are you using a common ground? You should be. If everything is routed and grounded good, you should not have to use any filters or ground loop isolators. It can be frustrating, but with a little work you will get it. DIYMA is a great forum with guys that have been at it a long time, along with many professionals, if you need more in depth help. Good luck to you sir
willis36 is offline
Fitting new stereo into Grand Cherokee Ltd edition les1466 Audio, CB & Ham Radios, GPS, & Electrical 21 10-09-2018 03:11 PM
New stereo install FM antenna adapter? Muskyhunter Audio, CB & Ham Radios, GPS, & Electrical 18 06-22-2018 12:12 PM
Replace Stock Stereo to Aftermarket - 2007 Jeep Grand Cherokee Laredo hlzma WK Grand Cherokee & XK Commander Forum 0 03-26-2018 01:21 AM
Stereo issues cbates670 Jeep CJ Forum 6 02-13-2018 03:18 PM
Aftermarket Stereo tyelliott23 WK2 Grand Cherokee Forum 6 01-31-2018 06:52 PM
