Starter relays - JeepForum.com
post #1 of 5 Old 06-14-2021, 06:04 AM Thread Starter
Ab257Z
Starter relays
So in the fuse box under the hood on my 2015 Rubicon, there are a bunch of 4 pin gray rectangular relays. I noticed that they are not all with the print on the relay facing in the same direction. Does it matter which way they are plugged in?
Ab257Z is offline
post #2 of 5 Old 06-14-2021, 07:39 AM
Pillswoj
Pillswoj's Avatar
2014 JK Wrangler
I believe they will only plug in one way.
Jeff
2014 2 dr Rubicon
Pillswoj is offline
post #3 of 5 Old 06-14-2021, 09:50 AM Thread Starter
Ab257Z
Hate to be contradictory, especially being a newby here, but the relays can be inserted either way, and work regardless of which way they are inserted. Maybe there is some software determining which way they are inserted.
Ab257Z is offline
post #4 of 5 Old 06-15-2021, 04:01 PM Thread Starter
Ab257Z
So it appears that rather than the two signal contacts being at one end of the rectangular relay and the output pins at the other, the input and outputs are at the diagonals across from each other. So it doesn’t matter from what I can see which way the 4 pin relay is inserted.
Ab257Z is offline
post #5 of 5 Old 06-20-2021, 12:04 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The relays can only be inserted one way. All the relays of the same size inside the PDC are the same and interchangeable. They cannot be inserted the wrong way.
Jerry Bransford is offline
