Sirius Tuner Install location 2005 TJ - JeepForum.com
post #1 of 18 Old 09-16-2007, 06:31 PM Thread Starter
sadlerb_98
2015 JK Wrangler
Tj Sirius Tuner Install location 2005 TJ
I posted to another thread but later decided it might be best to start a new one with the proper topic.
I've already installed a RB1 & Mopar iPod adapter and am looking to also install the Sirius tuner, installation kit for my model wrangler, and the artist cable. My question is where does the Sirius tuner go? Does anyone have their instructions from a previous install. I just want to make sure I have a good location for the tuner before I do the special order for these items.
Thanks,
Bob
sadlerb_98 is offline
post #2 of 18 Old 09-16-2007, 08:22 PM
Roughneck
Guest
I'm kinda going thru this myself. My jeep came with the SAT. On my 06 the SAT is mounted on a bracket behind the panel in front of your knees (very easy access). Actually your radio is still the tuner, the other thing is just the receiver. I searched and bought a few things and paid too much. Here is an online Mopar dealer that has the best prices www.trademotion.com/partlocator/index.cfm?siteid=213764 it should be Franklin Sussex dealership.
You'll need the SAT receiver, Rcvr-to-Mux (multipex) cable, and the Multiplex Splitter Unit. I know the cable & Mux is only about $90. I didn't price the Sat Receiver.
Roughneck is offline
post #3 of 18 Old 09-16-2007, 08:30 PM
Roughneck
Guest
Oh yeah, I am going thru something similiar. I am having a bracket built to mount all three "boxes" right there under the steering column & behind that knee panel. I'll try to get some pix as I go but it'll be about a week.
cheers, LT
post #4 of 18 Old 09-16-2007, 09:03 PM
HarleySteve
Guest
On my 05 Rubi TJ, I got the Sirius Install kit for the wrangler. It comes with a 'plate' style bracket. It is mounted using the two bolt holes for the pass side door strap ratainer. This kit also includes the antenna bracket and a cool fabric 'sirius-logo' cover. At $120 it's a little pricy but I think it is worth it for how well it's thought out.
Remove the two bolts holding that retainer on, connect all of the wires to the tuner, and slide the bracket/tuner up under the dash. There is also room on the sirius tuner to mount the mux box on the sirius tuner if you use double sided tape(I prefer the semi-perm stuff sold at Lowes). Once the bracket and tuner are up under the dash, use three hands and hold the bracket, the door strap retainer and start one of the bolts. Once you have one bolt on it gets real easy.
I was concerned with the sturdiness of the setup. But I have done alot of hard wheeling over the weeks since then, and have had ZERO issues.
HarleySteve is offline
post #5 of 18 Old 09-17-2007, 03:50 AM Thread Starter
sadlerb_98
2015 JK Wrangler
Tj
Thanks guys!
HarleySteve: Off the Jeep accessories website for an 05 wranger, I'm going to order the following:
82208586 Wrangle Installation Kit (hoping this is the one you described below)
82208908AA Sirius receiver
5066203AA Aritist cable
Do any of these part numbers look familiar?
Roughneck: great site. I've been using them for years. Thanks.
Bob
post #6 of 18 Old 09-17-2007, 07:14 AM
HarleySteve
Guest
Yup, those are the three parts I ordered! As well as the rcvr-to-mux cable, mux box and Ipod Integration kit.
I tried looking for my instruction sheet that came with the install kit, but can't find it. It has some excellent pictures to help you with the install! You will get it with the Sirius Install Kit.
post #7 of 18 Old 09-17-2007, 10:10 AM
Roughneck
Guest
I guess make sure you get the correct bracket for your year TJ. My 06 came factory with the SAT receiver mounted under the steering column. I'm just going to make a plate that I will bolt to the top of the original bracket and it will be big enouigh to mount the SAT, Mux, & Ipod side by side. There's plenty o room.
cheers, LT
post #8 of 18 Old 09-20-2007, 05:20 AM Thread Starter
sadlerb_98
2015 JK Wrangler
LT,
Roger. I will let everyone know how it turns out. Thanks for the tips everyone.
Bob
post #9 of 18 Old 09-26-2007, 05:33 PM Thread Starter
sadlerb_98
2015 JK Wrangler
Tj Hit a snag during install
Well, I was zipping right along with the install. I got to the point where I was to install the antenna and I opened the box and I had 1 tuner and no antenna. I will have to call the dealer I ordered the parts from and see when the can either swap out the tuner box and send a new tuner with antenna or see if they can send out just the antenna.
I am surprised about how straight forward the install is going to be.
I keep you guys up to date on the antenna.
Bob
post #10 of 18 Old 10-04-2007, 03:59 PM Thread Starter
sadlerb_98
2015 JK Wrangler
All finished
Finished the install today during lunch. All works great: RB1 unit with iPOD adapter and Sirius. I have artist info as well.
Thanks for all the tips.
Bobby
post #11 of 18 Old 10-05-2007, 11:25 AM
jeepin79
2008 KK Liberty
Bobby
Do you have the part #'s for what you used? I have the RB1 and ordered the SAT tuner and install kit but I want to make sure I have everything i need. I am ordering the IPOD hook up next.
jeepin79 is offline
post #12 of 18 Old 10-06-2007, 12:15 PM Thread Starter
sadlerb_98
2015 JK Wrangler
jeepin79,
I ordered:
82208586 Wrangler Installation Kit
5066203AA Optional Artist/title info cable
I would also recommend you go ahead and do the iPOD integration kit the same time. The optional artist/info cable will plug into the iPOD kit and plug into the Sirius receiver. The plugs are color coded so it is hard to mess it up. This way you get the artist info. I'm not sure if you can plug the artist cable from the Sirius receiver straight into the back of the RB1...
Good luck,
Bobby
post #13 of 18 Old 10-07-2007, 03:44 PM
Roughneck
Guest
Congrats on the install. I finally ordered the iPod stuff and waited 10 days, then when it was finally supposed to arrive at my door..... it never showed up. UPS lost the package. Now they're searching for it and I have to give them two weeks to locate it???? Then they can start the claim process.
cheers, LT
post #14 of 18 Old 10-07-2007, 07:40 PM Thread Starter
sadlerb_98
2015 JK Wrangler
LT,
Good grief. I know that must stink. Hopefully they find it quickly. I just got back from New Hampshire...going to bed.
Bobby
post #15 of 18 Old 10-08-2007, 12:19 PM
commodore_dude
commodore_dude's Avatar
Good luck,
Bobby
Yes, this is how I have it. Sirius Tuner>Multiplexer>RB1, using the artist cable from the mux to the radio.
2006 Rubicon Unlimited
2017 Mazda6 GT
commodore_dude is offline
need 12 volt source for sirius direct tuner purplepig Audio, CB & Ham Radios, GPS, & Electrical 27 02-02-2010 07:49 PM
Sirius tuner issues commodore_dude Audio, CB & Ham Radios, GPS, & Electrical 0 11-10-2009 12:22 PM
Sirius tuner installed and.... absentiabanish Audio, CB & Ham Radios, GPS, & Electrical 0 10-09-2006 01:05 PM
Hardwire Sirius One Tuner wenkebach Audio, CB & Ham Radios, GPS, & Electrical 4 08-14-2006 01:08 AM
Sirius radio tuner tommy4902 Audio, CB & Ham Radios, GPS, & Electrical 2 09-15-2005 01:59 PM
