Rigid chase light - JeepForum.com
post #1 of 5 Old 06-30-2020, 09:06 PM Thread Starter
docjrichey
Green Jeep Zombie Hunter
Rigid chase light
I have a RIGID chase light I need to install on my 2013 and I'm looking for detailed instructions. Website and customer service not very helpful. Any assistance would be greatly appreciated.
docjrichey is offline
post #2 of 5 Old 07-01-2020, 04:43 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
https://s3-us-west-2.amazonaws.com/r...structions.pdf
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 5 Old 07-01-2020, 07:41 PM Thread Starter
docjrichey
Rigid chase wiring
Thank you very much but that's the PDF I have. I am installing it on a mount on the back tire. The physical installation is no problem, I just need better instructions on the wiring.
post #4 of 5 Old 07-02-2020, 06:55 AM
cranbiz
cranbiz's Avatar
What exactly do you need to know? The wiring seems pretty straight forward to me.
Connect the red wire to the tail light wire
Your choice on the white or yellow wire for brake light wire depending on if you want steady burn or strobe.
Blue wire to backup light wire
Green wire to the dome lamp wire
Black to a suitable ground.
Wire Color / Function / Amp [email protected] DC
RED / Low Power Trail Light / .3a
WHITE / High Power Brake Light / 1.3a
YELLOW / High Power Strobe Flash / 1.3a
BLUE / Reverse Light / .7a
GREEN / Cargo or Courtesy Light / .3a
BLACK / Ground / N/A
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #5 of 5 Old 07-02-2020, 07:23 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
I would tap into most of these wires in or near the passenger side tail lamp.
White/yellow stripe = brake and turn signal
White/purple stripe = park lamp
White/green stripe = back up
Not all of the wires need to be used, or can be wired to toggle switches installed in your dash (like the cargo lamp).
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
