Remote start issues - JeepForum.com
post #1 of 11 Old 02-05-2020, 12:55 PM Thread Starter
ak2906
Unhappy Remote start issues
Hi. I took my 2018 Jeep GC Trailhawk 3.0L TDI to the dealership 6 times with the same issue: the remote start is intermittent. Sometimes it works and sometimes it doesn't. They reprogammed the software, check the battery and replaced the antenna and transmitter. It still doesn't work properly. Jeep service department is unable to fix the problem.
Any suggestions?
ak2906 is offline
post #2 of 11 Old 02-05-2020, 01:24 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
There is a list of conditions that must be met for RS to work. If any one of these systems has an issue (most commonly too low on fuel) it won't engage.
From the owner's manual:
All of the following conditions must be met before the engine will remote start:
• Gear Selector in PARK
• Doors closed
• Hood closed
• Liftgate closed
• Hazard switch off
• Brake switch inactive (brake pedal not pushed)
• Battery at an acceptable charge level
• PANIC button not pushed
• System not disabled from previous remote start event
• Vehicle alarm system indicator flashing
• Ignition in STOP/OFF position
• Fuel level meets minimum requirement
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 11 Old 02-06-2020, 12:12 PM Thread Starter
ak2906
I checked all of that. Full tank, doors locked etc.... Dealership is having trouble to figure this problem out. I'm getting a loaner and leaving my car at the dealership till they fix it. They think it's a software issue.
ak2906 is offline
post #4 of 11 Old 02-06-2020, 12:46 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
Any suggestions?
We're sorry to hear that you are experiencing this concern. If you would like any additional assistance, our team is always available via private message!
Alison
JeepCares
JeepCares is online now
post #5 of 11 Old 02-06-2020, 12:47 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Another common cause I've seen a number of times is a faulty hood switch causing the security system to think the hood isn't closed, which in turn disables the alarm system, thus disabling RS.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #6 of 11 Old 02-07-2020, 11:34 AM Thread Starter
ak2906
Thank you. I'll tell the Jeep mechanic.
ak2906 is offline
post #7 of 11 Old 02-08-2020, 08:59 PM
Morholt
If you try to remote start with the hood open, you'll see in the dash message saying something like, "remote start inoperative while hood open." So if the system is thinking the hood is open, it should be saying that. It also beeps at you when you attempt to remote start with the hood open.
Morholt is offline
post #8 of 11 Old 02-09-2020, 12:07 PM Thread Starter
ak2906
No warning messages at all. Everything seems to work properly. That's why it's so difficult to identify the problem. The dealership started a STAR case. I'm leaving my car at the service department for a few days. The manager is going to contact Jeep's engineering department and work with them. I hope they will be able to fix it this time.
ak2906 is offline
post #9 of 11 Old 02-19-2020, 11:16 AM Thread Starter
ak2906
So finally after two months and 7 visits to the Jeep service department my remote start problem got fixed. It was the battery. Apparently the first service department didn't check the battery properly.
ak2906 is offline
post #10 of 11 Old 02-21-2020, 09:41 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hello ak2906,
We are certainly sorry to hear about your experiences, however, we glad to see your concern was resolved. Please know our team is available in the future if needed. We're always happy to assist.
Laura
JeepCares
post #11 of 11 Old 03-19-2020, 11:37 AM
Areslano Aresso
Showbox jiofi.local.html tplinklogin
Areslano Aresso is offline
