No Power to Fuel Pump Relay - JeepForum.com
post #1 of 3 Old 07-10-2018, 10:09 AM Thread Starter
baddgerrnc
Yj No Power to Fuel Pump Relay
1990 Wrangler YJ 2.4L
Fuel pump not getting any power. Fuel pump tested good, relay tested good.
Is there a hidden fuseable link that powers this relay?
Can't seem to locate where the power source originates on this.
Was able to rig a temporary bypass to get it home.
Any help would be appreciated
Thanks
BaddgerrNC
baddgerrnc is offline
post #2 of 3 Old 07-10-2018, 11:27 AM
jtec
jtec's Avatar
2014 JK Wrangler
see attachment.
You could jump cavities at FP relay with a fused jump wire.
jtec is online now
post #3 of 3 Old 07-31-2018, 01:42 PM
Stitch586
Stitch586's Avatar
Thanks
BaddgerrNC
Check your ground....
It will most likely be near your parking brake foot peddle. If you have a good ground then check the ground wire going back to the pump for splices or nicks in it.
91 YJ 4.0/AX15/231J AA SYE/ Tom Woods CV
3.5" BDS Springs / .75" Booms / 1"BL
HP D30 /Akebono's /1 Ton GM Crossover Steering
Ford 8.8 / Trac loc LSD w/ disc brakes
35x12.5x16 Nitto Trail Grapplers
Walbro255 MetalCloaks
Kilo-Echo-8 * * *
Stitch586 is offline
electrical , fuel pump , fuse
