Need ECU PCM for 97 TJ 2.5L manual - JeepForum.com
post #1 of 4 Old 07-27-2010, 09:36 PM Thread Starter
vfasburg
If anyone has a working one let me know how much you want for it. Also, one mechanic told me that any pcm from a 97 with a 2.5 and stick shift would work, and another told me it would have to have the same code written on it. Does anyone know which of these is true?
vfasburg is offline
post #2 of 4 Old 07-28-2010, 12:44 AM
RogueSpear2023
I think any PCM from a 97 2.5L with a stick will work, even one from an auto may work, I can't remember if the PCM and TCM need to communicate on the older jeeps. But I would just use one from a stick shift and you should be fine. Davey's Jeeps is probably a good place to find one.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #3 of 4 Old 04-16-2011, 06:31 AM
rockwallchamp09
rockwallchamp09's Avatar
This is from solopcms.com Details
PCM, ECU, ECM for 1997 Thru 1999 Jeep Wrangler 2.5L or 4.0L. It is very important to obtain original unit part number, this year requires that the part numbers be matched. Federal or California Emissions are determined by Vin Number and Part Number provided.
They run about 245$ new
rockwallchamp09 is offline
post #4 of 4 Old 12-19-2013, 08:28 AM
Lildaryl
1997 ecu swap
I have a 1997 jeep wrangler Tj I swapped the 2.5 with a 1992 4.0 if I but an ecu and add two wires for my injectors does the new ecu need to be programmed in any way before installing it
Lildaryl is offline
ecm , ecu , parts , pcm
Crawling with a manual? onlyinayj89 General Jeep & Off-Road Equipment 17 03-24-2009 01:28 PM
AX 15 Manual goconnor Engines & Drivetrain 2 07-25-2007 07:23 AM
S&R Manual on CD HAB Cheap Tricks & Fixes 0 11-19-2006 07:30 PM
87 Manual Transmission duke32 Engines & Drivetrain 8 09-01-2006 08:31 PM
RB1 Owners' Manual leicajh Audio, CB & Ham Radios, GPS, & Electrical 1 07-24-2006 02:45 AM
