LED turn signals not working - JeepForum.com
post #1 of 2 Old 07-27-2014, 03:50 PM Thread Starter
Klinestine
I've looked everywhere and cannot seem to find anyone with a similar issue. I just installed the Metalcloak Overlines on my TJ. I installed the LED lights as instructed and have hit a wall. No matter which way I match up the wires, I cannot get my turn signals to work. The hazards, running and front lights all work just fine.
I tired the trick I saw about turning on the hazards and then switching to your turn signals, but that only works for a flash or two and then nothing. I have no clue what's stopping them. Help???
I've switched the wires, tried running it with the engine off and on, used both the designated LED and original relay, and replaced the fuses. All to no avail.
Klinestine is offline
post #2 of 2 Old 08-04-2014, 10:54 PM
R32Smith
I would call MetalCloak and see if tech support can help. Normally LED's will require a load resistor or LED Relay. Since you say you already swapped things around with the relay, maybe you got a bad set of lights.
R32Smith is offline
head light , headlight , led , metal cloak , metalcloak
