IPF Reverse Light Not Working - JeepForum.com
post #1 of 3 Old 09-23-2019, 03:40 PM Thread Starter
jfondren3
jfondren3's Avatar
2015 JK Wrangler
Jk IPF Reverse Light Not Working
Today I wired up an IPF Reverse Light 8161, on my 2015 JKU Rubicon but the light does not work at all. When I put the three way position switch in the ON position the green light on the switch lights up. If I put it in the second ON position the green light on top of the switch will light up when I shift into reverse. The actual reverse light never turns on though.
I checked the voltage at the plug on the light and I’m getting 12.6V after I fixed a grounding issue. I also double checked the inline fuses and they are good.
Any ideas on what I could check next or what the problem may be?
Thanks
2015 Jeep Wrangler Unlimited Rubicon Hard Rock
Air Force Jeep Club #131
jfondren3 is offline
post #2 of 3 Old 09-23-2019, 04:53 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
If you're getting power at the light and it's not illuminating, the problem is in the light...whether it's faulty wiring, a defective connector, or just a blown bulb.
Test the light socket for voltage. If you're getting it there, it's just a bad bulb.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 3 Old 09-23-2019, 05:31 PM Thread Starter
jfondren3
jfondren3's Avatar
2015 JK Wrangler
Thanks for the reply Kruzin. I went back out and measured at the light and I was getting 8-9V. So I cut a piece of wire and touched the ground to a known good chassis ground and it lit up. After that I redid the ground wire where I had it attached on my swing away tire carrier. A bad ground will get you every time. But it’s working now as it should. Time to start figuring out the next mod.
