Installing a heater in an 81 CJ5 - JeepForum.com
post #1 of 3 Old 09-29-2019, 05:22 PM Thread Starter
mhobson3
Admitted Jeep n00b here and this is my first post. I purchased an 81 CJ5 with no heater in it. Anyone have a thread, link or video as to how to install one? Recommendations for a brand vs OEM? I read a little about Mojave heaters but couldn't find a ton of info. Thanks in advance!
mhobson3 is offline
post #2 of 3 Old 09-29-2019, 06:42 PM
mukluk
mukluk's Avatar
If you're thinking about installing an electric heater in your Jeep, just stop now. Unless you're towing a sizeable generator behind the Jeep to power said heater, you simply aren't going to generate enough power to run an electric heater that comes close to the same output as a conventional automotive unit that uses the engine's waste heat.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 3 Old 10-02-2019, 05:40 AM
V8GCZJ
You can get stand alone units like the Mojave that hook up to coolant lines from the motor.
https://www.summitracing.com/parts/sum-991102-1/
V8GCZJ is offline
