how to remove wire pin from harness - JeepForum.com
post #1 of 7 Old 03-27-2020, 06:52 AM Thread Starter
solarissf
i've watched so many videos and I must be doing something wrong because this damn wire will not come out. I have tools so can someone please tell me the proper way to remove this pin?
solarissf is offline
post #2 of 7 Old 03-27-2020, 09:14 AM
cranbiz
cranbiz's Avatar
It looks you are attacking the right area. The small slot contains the locking tab but it's usually recessed somewhat deeply in the plastic. You just have to get the tool deep enough and probably have to play with it to depress the locking tab far enough to release.
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #3 of 7 Old 03-27-2020, 11:19 AM Thread Starter
solarissf
in the very middle... or the left side of the copper piece... or that tiny tiny dot on the right side?
post #4 of 7 Old 03-27-2020, 12:00 PM
mukluk
mukluk's Avatar
What does the back side of the connector look like?
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #5 of 7 Old 03-28-2020, 02:34 AM
Ralph77
X2. Some connectors have a little locking tab that you have to push down from the front, the orientation of the picture you showed, and pull the wire out the back.
Some require removing stuff off the back to pull it out in that direction.
Ralph77 is online now
post #6 of 7 Old 04-04-2020, 05:45 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
Why are you trying to remove it? Why not just cut the wire that is attached to it? To remove it the right way you need a depinning tool although a small set of picks can sometimes get the job done.
Necromancer_tat is offline
post #7 of 7 Old 04-06-2020, 12:36 PM Thread Starter
solarissf
well i tried and tried and it finally popped out. I actually do not know where exactly I pushed down but its out now. I could have cut it but I was mentally just scared about cutting a factor wire.
