hella 500's - JeepForum.com
post #1 of 6 Old 05-18-2010, 05:33 AM Thread Starter
Cilaes
hella 500's
I just bought a set of Hella 500's and some windshield mounts and started installing then yesterday, but I have a few questions for you guys that have done these before.
When you guys feed the wires from the lights under the panel how are you getting them into the engine bay? Do you have to drill a hole?
Do the gnd wires from the light have to run to the battery negative? And is the ground on the hellas for some reason the blue instead of the black?
Also... where is the wire to splice into for high beams?
Thanks in advance.
'04 Rubicon; 33x12.5R15 Goodyear Duratrac's; 15x8 Unique 297 Wheels; 2.5" RC Sus. Lift; RC 1.25" BL; RC Steering Stabilizer; Hidden Hitch; Green LED Guage Lights; MY BUILD: https://www.jeepforum.com/forum/f22/oh-my-darlin-04-rubi-1032255/
Cilaes is offline
post #2 of 6 Old 05-18-2010, 05:05 PM
SirGCal
RIP
SirGCal's Avatar
Yes you will have to drill a hole and use gromets to get through the cowl and engine area.
No ground does not have to go back to the battery. Ground under the cowl at the most convenient location.
I used the unused output from the stock fog/high-beam/bypass relay to trigger it on only for high-beam use. Simple and easy. Just use that output as the switched 12v trigger to your switch, then new relay.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 6 Old 05-19-2010, 10:13 AM Thread Starter
Cilaes
What exactly IS the cowl?
Where is this?
Cilaes is offline
post #4 of 6 Old 05-19-2010, 10:16 AM
ClimbStuff
Where is this?
That panel that buts up against the windshield, runs along underneath the wipers, that has the venting in the middle.
ClimbStuff is offline
post #5 of 6 Old 05-19-2010, 10:20 AM
SirGCal
RIP
SirGCal's Avatar
The space between the hood and windshield.
Where is this?
Above the fuse box on mine. They moved around a few different years.
SirGCal is offline
post #6 of 6 Old 05-23-2010, 08:39 AM
JJR00XJ
I'm pretty sure there is a big old rubber grommet on the driver side where the main harness goes through the firewall. Use some kind of poker, I like to use old car antennas, and tape your wires to it then push it through the rubber grommet. I would drill the firewall as a last resort in a TJ, I don't drill unless I absolutely have to. JMHO
If it ain't broke Don't fix it.......
JJR00XJ is offline
500 , ff 500 , hella , wiring
Hella 500's SCFishinGuy Audio, CB & Ham Radios, GPS, & Electrical 6 01-10-2007 08:39 PM
Hella 500's tmwoodall General Jeep & Off-Road Equipment 5 12-07-2006 11:01 AM
hella 500's dig'umz Audio, CB & Ham Radios, GPS, & Electrical 8 11-16-2006 07:49 PM
Hella 500's joedirt88 Audio, CB & Ham Radios, GPS, & Electrical 2 10-02-2006 12:24 PM
Hella 500's silvergreentj Audio, CB & Ham Radios, GPS, & Electrical 2 01-24-2006 11:55 PM
