factory sub to an aftermarket radio - JeepForum.com
post #1 of 14 Old 05-26-2010, 06:18 PM Thread Starter
djmarine
how do you hook up the factory sub to a aftermarket radio? I have a 2006 jeep rubicon and i cant figure out how or where i would hook it up to the clarion deck. does anyone know thanks
djmarine is offline
post #2 of 14 Old 05-26-2010, 06:22 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Connect the new deck using the factory speaker wires, the sub is connected via the factory f/r speaker wiring. You only need to connect the TJ's blue "amp turn on" wire to the Clarion's Blue power antenna or amp turn on wire. The sub's amplifier is powered by that blue wire that the Clarion will power whenever the Clarion is turned on.
Jerry Bransford is offline
post #3 of 14 Old 05-26-2010, 07:03 PM Thread Starter
djmarine
i have 2 blue wires with a pink stripe no solid blue wires and the 2 blue wires look hooked up to the harness going in to the clarion.
djmarine is offline
post #4 of 14 Old 05-26-2010, 07:34 PM
Jerry Bransford
Administrator
I am not sure what you are saying there. But if the sub works after the Clarion's f/r speaker wires are spliced into the Jeep's f/r speaker wiring, you have the correct blue wires connected.
post #5 of 14 Old 05-27-2010, 12:37 AM
Demp
Jerry is correct, the sub amp is hooked to the 2 rear speaker signals. When I removed my console sub there was only the 4 signal wires and a power and ground, the amp is signal sensitive instead of remote (blue wire) triggered.
There could be a built in relay for the sub's power elsewhere using the radio's remote line, however. If you used a harness to fit the chrysler connector just match up the remote labeled wires and you are fine.
Demp is offline
post #6 of 14 Old 05-27-2010, 10:29 AM
Jerry Bransford
Administrator
Maybe but even with that, it needs the blue wire connected for power. That is where it gets its power from.
post #7 of 14 Old 05-28-2010, 01:55 AM
shinna202
sorry to hijack your thread, but what if the factory sub works with only radio as in FM/AM, however when I go to UBS to use my ipod, the sub does not work anymore?
shinna202 is offline
post #8 of 14 Old 05-28-2010, 09:26 AM
SirGCal
RIP
SirGCal's Avatar
The wrong (power antenna) wire was used to trigger the amp (remote-turn-on).
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #9 of 14 Old 05-28-2010, 09:52 AM
shinna202
So which two colors should be attached then?
post #10 of 14 Old 05-28-2010, 09:57 AM
SirGCal
RIP
SirGCal's Avatar
The colors are not 100% standard. They can very. The two wires from the new radio though are likely blue and blue with a white stripe. Find which one is connected, and which one is not, and switch them.
SirGCal is offline
post #11 of 14 Old 05-31-2010, 01:21 PM
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
I just replaced my headunit, and have the exact same problem. Sub works with the radio, but not iPhone or CD.
I know I matched the wires right, by reading the label on each one. However, the problem still exists. Is it okay to switch the wires, or am I going to hurt something? What's the worst thing that could happen if I connect the power antenna to the remote turn on lead?
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build thread
dogbluedrummer is offline
post #12 of 14 Old 05-31-2010, 01:46 PM
rubibluejay
https://www.jeepforum.com/forum/f20/l...9/#post8219106
Jay
rubibluejay is offline
post #13 of 14 Old 05-31-2010, 03:46 PM
dogbluedrummer
Trust me....
I swapped the wires....and amazingly it all works now! Thanks guys.
Now I just need to add a little bigger amp for the sub.......money, money, money......
My build thread
post #14 of 14 Old 12-27-2015, 05:35 PM
Jimistark
sub woos
i just bought a 05 with a Kenwood KDC152 head unit, the sub works but sound like a full range speaker, I unpluged the factory amp fuse and it turns the sub off so i guess the amp is working. I am guessing all the speakers are factory except the sub, its a Kicker, I can see it. The point is my Amazon bluetooth black box sounds better. Can anyone recommend a decent fix that doesn't cost a grand. Thanks
Jimistark is offline
Loss of factory sub with aftermarket radio - 2006 LJ MattGigEm Audio, CB & Ham Radios, GPS, & Electrical 34 08-25-2012 04:03 PM
Which Radio Replacement Interface do i need for a aftermarket radio? w4rh4wk Audio, CB & Ham Radios, GPS, & Electrical 1 03-20-2009 03:50 PM
Factory Radio, Aftermarket Amp for Spkrs. baff2004 Audio, CB & Ham Radios, GPS, & Electrical 2 10-05-2006 06:06 PM
Factory sub and aftermarket radio absentiabanish Audio, CB & Ham Radios, GPS, & Electrical 0 10-02-2006 06:45 PM
Factory CD Changer on Aftermarket Radio? JayIV Audio, CB & Ham Radios, GPS, & Electrical 0 09-16-2006 09:13 AM
