Craigslist CB - JeepForum.com
post #1 of 27 Old 04-28-2010, 08:46 PM Thread Starter
Fhajad
Fhajad's Avatar
Craigslist CB
So I just bought two CBs and some Coax cabling off Craigslist for $20. They both work in the sense they power on. They came with a tiny lil' antenna I'm not even gonna bother with, this thing has a magnetic base and is barely a foot high!
So I'm thinking of grabbing a 4 foot Firestik (Amazon.com: FireStik FS4-B 4' Black Antenna w/ Tuneable Tip: Electronics) and I want to mount it onto the side of the tire stopper on the rear passenger side.
Will this result in a good setup? How would I go about mounting the Firestik and such? I also need to get a SWR tuner. Anyone got a good one to recommend?
I might stop by the local truck stop to see if they have the Firestik and tuner instead of buying it online and paying the shipping.
EDIT: Is this all I'd need in a SWR Tuner or is there one any cheaper? http://www.amazon.com/METER-Radio-An...2512421&sr=8-2
Fhajad is offline
post #2 of 27 Old 04-28-2010, 10:35 PM Thread Starter
Fhajad
Fhajad's Avatar
Also, I can't find anything that well to dictate HOW to wire up an antenna. Will my coaxial cable work with the Firestik? How does the Firestik sit in a mount and connect to the cable?
I can't find a good over view on it anywhere and I'd to know for sure what I need to buy.
Fhajad is offline
post #3 of 27 Old 04-29-2010, 03:37 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Coax cable should be replaced if it is old or shows signs of damage.
Firestik.com has great Tech and FAQ pages that answer any antenna questions and solve most problems. The info applies to any brand of CB antenna.
Firestik has many types of CB antenna mounting brackets and shows how to assemble your antenna, coax, antenna stud, and mounting bracket.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #4 of 27 Old 04-29-2010, 11:41 AM Thread Starter
Fhajad
Fhajad's Avatar
Started reading through the Firestik.com stuff. And I discovered even though the Coax I have is new, it's meant for dual antenna, not single.
Anyone know if it's possible to just get 15 foot Coaxial anywhere? Cause I'd rather not have to keep 10 feet of cable under my seats and keep the run as small as possible.
Fhajad is offline
post #5 of 27 Old 04-29-2010, 12:53 PM
mylt1
mylt1's Avatar
what do you mean its meant for 2 antennas? does it have 3 ends, one on a single wire and they a Y with an end on each lead? as for the cable, you can buy it from several places on the net and buy the ends as well and just make your own cable as long as you need it.
mylt1 is offline
post #6 of 27 Old 04-29-2010, 01:06 PM Thread Starter
Fhajad
Fhajad's Avatar
It's RG-59 where as single specs call for RG-58.
I'm looking here on Amazon: Amazon.com: 15 RG-58: Electronics and not sure 100% what the name of the connector is to make sure what I need. What I have now has a flattened spot on the edge of the radio. Which of these gives me that result?
Fhajad is offline
post #7 of 27 Old 04-29-2010, 01:07 PM
little_Jeep
little_Jeep's Avatar
There is a Pilot Truck stop off I-65 to the South of you (Cementville?) that has a real good CB shop in it. They have lots of Firestic stuff as well as a Tech on staff.... or at least they did last time I was there (a few years ago). 18 foot is the shortest coax that I know of.
Go to Stu Olsen's Web site for more information and installation help.
CB Radio Antenna Installation
Exposing the 18' CB Coax Myth
In our area, you will want a 3 foot antenna mounted about spare tire high for trail use.... any higher, antenna just gets knocked off by brush. If you want to use CB on highway, you will need to get an additional 4 foot Firestic (approx. $20.00) The longer antenna will rise about your roof line better which is what you want for highway use. Don't buy those silly springs thinking it will allow you to use only one antenna,,, don't work, I have been there, done that
little_Jeep is offline
post #8 of 27 Old 04-29-2010, 01:49 PM Thread Starter
Fhajad
Fhajad's Avatar
Roughly 190 mile round trip seems a bit much for a lil' ol' CB setup on a Jeep. I'll give a look at the Pilot near my house tonight and see what they have. Hopefully I can find some of these for cheaper than Amazon (At least in shipping especially)
I'm planning on a 4' since I mostly do highway driving right now and it's my DD to/from work 40 miles each way. Whenever I start doing a lot more off road, I'll put in a 3' and sell off the 4' or something.
Thanks for the reading material!
Fhajad is offline
post #9 of 27 Old 04-29-2010, 02:00 PM
little_Jeep
Oppppppps. I was thinking of wrong town. Forgive me. Look for a Pilot Truck stop in your area, they all sell firestic Antenna's and stuff. Thry all have a real good selection of CB stuff.... SOME Pilot Truck Stops have a full CB sales/repair/service shop as Truckers are their main client.
post #10 of 27 Old 04-29-2010, 02:07 PM Thread Starter
Fhajad
Fhajad's Avatar
Cementville is south about 80 miles. It's not far, but it's far enough. (Shelbyville is along I-74)
The nearest Pilot is literally 4 miles away, so I'll just head over there.
Fhajad is offline
post #11 of 27 Old 04-29-2010, 02:16 PM
little_Jeep
I haven't look at a map, but you are Southeast of Indy IIRC. If you are not a member of Indiana Four Wheel Drive Association (Indiana 4WD Association - Home Page) you need to be. I was originally thinking Shelbyville was just North of Memphis, IN.
BTW, the Firestic antenna's just screw into the base, so once you have the antennas tuned to the vehicle, you can swap from the 3 foot to the 4 foot as much as you desire.
post #12 of 27 Old 04-29-2010, 02:21 PM Thread Starter
Fhajad
Fhajad's Avatar
Sounds good on all counts.
So pretty much I just need to get a Coax cable, a mount, the Firestik and a tuner and good to go? I'll report back after I return from Pilot. I got the price if I order that all online and I'll compare. If it's the same or not even that much more, I'll pull the trigger for it.
Fhajad is offline
post #13 of 27 Old 04-29-2010, 02:24 PM
little_Jeep
Some places will charge you like $5.00 to tune the antenna once you install the CB and all.. The SWR meter is approximately $30.00 and really is only needed when you get a new antenna.
post #14 of 27 Old 04-29-2010, 03:02 PM
mylt1
mylt1's Avatar
RG-59 is TV cable. it is also 75ohm instead of the 50ohm RG-58 is. the connector on the radio is a PL259. they are available in both solder on and non solder from radio shack in the electronics bin. its a bin that looks like a tool chest. you can get RG-58 from rat shack as well but you can get better quality stuff on the web.
mylt1 is offline
post #15 of 27 Old 04-29-2010, 03:16 PM Thread Starter
Fhajad
Fhajad's Avatar
I got one anyway. Roughly $22 for it. Overall I just spent $75 which was only about $10 over my Amazon costs total so worth the non-wait. And who knows, some of my friends might get a CB now and need to borrow it.
I went ahead and bought finished cable. If I had a spool of RG-59 sitting around I'd do that plan but I don't.
Fhajad is offline
Craigslist Shop Compressor Opinion SuperWade2 Fabrication Shop 16 04-05-2010 06:41 AM
Check out this deal I found on Craigslist, NJ and MA NJMike Fabrication Shop 2 09-20-2009 01:20 PM
Found on Craigslist (not mine) TNeustadt General Jeep & Off-Road Equipment 0 09-01-2009 04:46 AM
Craigslist is the best thing to ever happen to me.... sprowley Tires & Wheels 8 08-17-2009 04:44 PM
warn 8274 for $550 on craigslist JIBTEXHNKA General Jeep & Off-Road Equipment 0 05-06-2009 10:00 PM
