Cj fuel sender - JeepForum.com
post #1 of 4 Old 01-07-2020, 04:04 PM Thread Starter
brandonll
Cj fuel sender
Does anyone have a suggestion on were to find 12v sending units?
I have a 1980 CJ-5 with the stock fuel tank with 2" hole for sender. Problem is that I replaced my gauges with Stewart Warner 12V, so now my gauge indicates a good half tank when completely empty. I already removed the sender and tested to make sure there wasn't a short someware. The senders Stewart Warner recommend for their gauges won't fit my tank. Surly lots of people have switched to 12 v gauges, but where can I find stuff that fits stock applications? The gauge I have is 73 OHM which is the same as the stock 6V was. Would appreciate any input. Thanks
brandonll is offline
post #2 of 4 Old 01-14-2020, 03:10 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
Had a similar issue. I just bent the arm that holds the fuel level float and with testing got it right. It’s easier on an empty tank. We did it with tank out of vehicle and some extension wires.
Good luck.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #3 of 4 Old 01-14-2020, 12:57 PM
Fourtrail
1974 CJ6
Are you running 12v to your new gauge? Or are you still hooked up through the factory voltage reducer for power to the gauge? The sending unit doesn't care if you are using 12v or 6v.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #4 of 4 Old 01-14-2020, 05:04 PM Thread Starter
brandonll
I am using new 12 v gauge powered by 12 v. The voltage reducer went away with the old gauge.
So can I run 12v from the gauge to the original 6v sender without burning it up? If so, I should be OK. maybe just need to bend float arm as RARECJ8 recomended.
