CB sound is crappy, is it due to poor cable quality? - JeepForum.com
post #1 of 25 Old 04-23-2007, 09:13 PM Thread Starter
Sky Hye
Sky Hye's Avatar
I had a cb in my YJ years ago, it got totaled so i took it out and it sit in the garage. Now I installed it into my new TJ and it isnt as loud as it was before. I noticed the cables were a little corroded looking. It kinda gets louder when I wiggle the plug around. I tried fooling with tthe volume and squelch, no avail. You guys think a new cable would solve the problem? or might it be the CB itself?
Sky Hye is offline
post #2 of 25 Old 04-24-2007, 12:15 AM Thread Starter
Sky Hye
Sky Hye's Avatar
Sky Hye is offline
post #3 of 25 Old 04-24-2007, 12:18 AM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
Go the cheapest route first, get a new cable!
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #4 of 25 Old 04-24-2007, 11:21 AM
mpyusko
the cable most likely. Also, you might want to find an SWR meter. Radio Shack sells them for like $35. It will help you tune your CB, Cable, and Antenna to peak performance.
Also, it helps to have a really clean contact between your antenna/mount/body. The antenna relies on your vehicle as a ground plane. It affects the reception considerably.
-mpyusko
_________
'97 SE Black, 4cyl/5spd, Soft top, Jeeperman Rear Bumper, 33x12.5x15 Trxus M/T's, 4" Lift, 1" JKS MML
BLACK JEEP Club V2.0 #84
Rust-Bucket Build-Ups Club Member
mpyusko is offline
post #5 of 25 Old 04-24-2007, 11:36 AM
Chris @ GATR
Chris @ GATR's Avatar
2 most important factors in radio transmission and receive quality are:
1. Good quality RGX or Mini8
2. Antenna tuned properly with SWR meter.
Got ignorance? Please see below.
Originally Posted by kd4yor View Post
Chris, I just think your having buyers remorse for all the work in your 8.8 for no added gain (over the Dana 35).
Chris @ GATR is offline
post #6 of 25 Old 04-24-2007, 01:02 PM
03jeeper78
03jeeper78's Avatar
I would definitely add a good ground connection to that list.
'03 Bright Silver Metallic TJ Sport
BSMCCEP Club Member #45
Stock: 4.0L I6:5-speed:3.07 gears:D35 with Trac-Loc:15x7 Ecco wheels:Dual Top Group
Mods: 30x9.5 BFG A-T T/A KO's:JKS Quicker disconnects:Rock-It Man rocker guards:Jeep Medic oil pan/tranny skid:Kilby steering skid:Warn D30 diff guard:C4x4 D35 diff guard:Rusty's radiator guard:Skid Row LCA skids:SilverStar headlights and fogs:Hidden Hitch class III receiver:Old Realistic 40ch CB:2' Firestik II:Arizona Rocky Road tailgate antenna mount
Next : Jeeperman rear bumper
'06 Candy Orange Honda Shadow Spirit 750
03jeeper78 is offline
post #7 of 25 Old 04-24-2007, 02:42 PM
mylt1
mylt1's Avatar
what cables are you talking about?
mylt1 is offline
post #8 of 25 Old 04-24-2007, 07:07 PM Thread Starter
Sky Hye
Sky Hye's Avatar
What is a rgx or mini8? I have the antenna bolted to the spare tire carrier (stock) and the andenna is a 64" whip. it attaches to the coil via an allen. can this be tuned? if so how?
Sky Hye is offline
post #9 of 25 Old 04-24-2007, 07:13 PM Thread Starter
Sky Hye
Sky Hye's Avatar
Dont bash me, Radio Shack. I just want something that i can use while out with the club on the trails. Is there any way of testing the cb without another cb to make sure it works properly?
Sky Hye is offline
post #10 of 25 Old 04-24-2007, 07:22 PM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Either check or have cheked the SWR (Standing Wave Ratio) of the System.
If it is in the area of 1.1 to 1.5 to 1 then your connections to the antenna are OK.
If above that then you have to have things checked out, connections, coax and ground strap connections.
Sometimes it is as easy as running a ground strap from the Antenna Mount to the Frame, sometimes not.
Start by checking the SWR; see where that takes you then you have a reference point.
The Coax at Rat Shaq will work, yes, but it will also bring in noise and lose more power on transmissions.
I am a against Rat Shaq only because I believe they are taking advantage of people by selling inferior products, I don't mean to bash anyone just the Rat shaq Products.
If you notice Rat Shaq is selling Name Brand Products, they are going away from the Radio Shack Name.
Luck on the project,
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #11 of 25 Old 04-24-2007, 07:26 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
RG8X and Mini8 is simply a bigger diameter cable than the standard RG58 cable most CB'rs use. That said, as someone who has been using RG8, RG8x, min-8 and other coaxes since the sixties, you won't be able to tell the difference on a 4 watt CB with basic less costly more flexible RG58. There's simply not enough loss in the 12-15' length of antenna cable for it to make any difference to a CB by using RG58.
Yes it could be tuned but unless it can be moved up and down after loosening the allen bolt, it won't be easy. If it can be moved up and down in the mount, then it can. Use an SWR meter (they include instructions) to tune for minimum SWR and the antenna is tuned.
A mistuned antenna will not affect how well it receives however, that only affects how well it transmits.
So far as things making noise when you wiggle a cable, which cable are you talking about? The antenna cable or power cable? Either way, a connection is likely just corroded which could probably be fixed by just cleaning it up and maybe resoldering it.
Jerry Bransford is offline
post #12 of 25 Old 04-24-2007, 08:17 PM
Jerry Bransford
Administrator
(two identical threads merged into this one)
post #13 of 25 Old 04-24-2007, 11:19 PM Thread Starter
Sky Hye
Sky Hye's Avatar
The coax cable is what made noise. I think i might have it too long as well, there was plenty extra so i tucked it under the carpet, probably a bad idea. It seems many of the CB/ trucker shops are closing around Los Angeles. Anybody recommend someplace to get some cable? What length should I buy? I have it coming out the back, where the tailgate hinges and it is mounted on the spare tire carrier.
Thanks
Sky Hye is offline
post #14 of 25 Old 04-24-2007, 11:21 PM
mpyusko
radio shack or the ever famous "Internet".
-mpyusko
_________
mpyusko is offline
post #15 of 25 Old 04-24-2007, 11:35 PM Thread Starter
Sky Hye
Sky Hye's Avatar
Im through with radio shack, they dont know squat there.
Sky Hye is offline
Why Do My New JL Audios Sound So Crappy? UKFan4Sure! Audio, CB & Ham Radios, GPS, & Electrical 20 05-02-2009 10:59 PM
Sound Quality in custom soundbar bobcatfanman14 Audio, CB & Ham Radios, GPS, & Electrical 1 02-09-2009 08:23 PM
Speaker Wire -vs- Sound Quality DrViffer Audio, CB & Ham Radios, GPS, & Electrical 3 04-30-2006 10:45 AM
XM sound quality 1STONER Audio, CB & Ham Radios, GPS, & Electrical 8 05-05-2005 10:37 AM
sound quality 97TJWRANGLER Audio, CB & Ham Radios, GPS, & Electrical 1 01-02-2003 04:49 PM
