CB price?? - JeepForum.com
post #1 of 19 Old 03-11-2009, 09:05 PM Thread Starter
keaton
keaton's Avatar
CB price??
So i was lookin for cb's online while i was at work today. Found this::
http://www.walcottcb.com/complete-pa...th=340_377_379
Now i know i still gotta get the rest of the ****. Antenna, antenna mount and coax cable. Priced it all out and it came to about 130. Is that way too much?
The antenna was a Firestik 4' Firefly for 20. Some generic mount for 20. And a 18' coax cable for 22. Seems like thats way too high but am i wrong?
My Rigs:
2000 XJ
2003 TJ
keaton is offline
post #2 of 19 Old 03-11-2009, 09:22 PM
MudDuck99
MudDuck99's Avatar
2014 JK Wrangler
wal mart sells a cobra cb for like 30 bucks. it's the one i have and works great. As far as antenna and coax: check out some local truckstops. Definitely the way to go
MudDuck99 is offline
post #3 of 19 Old 03-12-2009, 08:07 PM
fedrusion
Your gonna spend 100 for a decent set up. I have a $30 Cobra from wally world and a good firestik antenna and cable. A good antenna will make your system, make sure you get it tuned.
1999 Cherokee 2 Door Sport (To be modified) Mine.
5.5" Composite lift, Rough Country Control Arm Drop Brackets, 31X10.5X15 Dayton Timberline AT's On Canyons, 31X10.5 Firestone Destination MT's, P.O.R.C. SYE and front CV Drive Shaft, Homemade Short Ram Intake, Locked 8.25. Comming Soon: Stroker.
2000 Grand Cherokee Laredo (To be left alone) Wife's.
fedrusion is offline
post #4 of 19 Old 03-12-2009, 08:19 PM Thread Starter
keaton
keaton's Avatar
Oh yeah...a swr meter is in that price i posted too.
Im not tryin to cheap out on it so i might just go with what i was lookin at. Dont need anything crazy but wanna get the right stuff.
My Rigs:
2000 XJ
2003 TJ
keaton is offline
post #5 of 19 Old 03-12-2009, 08:45 PM
mxracer513
Check a truck stop, compare prices, go from there.
My Dually CJ Restoration
../|,[____],
.i.---L-[]IIII[]-
()_) ()_)-o-)_)
KB3RDF ..... Yellow Jeep Club Member # 513
mxracer513 is offline
post #6 of 19 Old 03-13-2009, 03:14 PM
fedrusion
Like I said, just make sure you have a good antenna. A cheap antenna on the best CB will only be as good as the cheap antenna. A cheap CB with a good antenna will perform just as well as a high end CB with a good antenna.
And the cheap CB's usually have less features making them simpler to use.
post #7 of 19 Old 03-13-2009, 03:25 PM
malibubts
malibubts's Avatar
x2 You can get that Cobra 19 at Wally World. And that price sounds about right, my setup was around there. Good setup though, a lot of people run that 4' Firestick and it's a good antenna. Good Luck!
Eric - '02 Laredo Grand Cherokee
malibubts is offline
post #8 of 19 Old 03-13-2009, 04:16 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Figure out where you're going to mount the antenna before deciding on the length. If it'll be fairly high up like at tail light or spare tire mounting bracket level, a 3' will likely be a better choice for clearance reasons. Performance wise, there's not that much difference between a 3' and 4'... especially on the trail. Heck my 2' antenna works just fine for the trail.
Jerry Bransford is offline
post #9 of 19 Old 03-14-2009, 10:07 PM
sduncan
sduncan's Avatar
Today I got a new Uniden 510 ProXL on ebay for $40 (including shipping). I also ordered a Firestik 2FS tuneable antennea, Firestik stud mount and Fireflex coax from trucker-store.com . $60 for all with shipping. The top of the antennea should be even or a couple inches above the height of my hardtop with the mount I have in mind. This will be all I need for my uses and should be great on the trail.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #10 of 19 Old 03-14-2009, 10:11 PM Thread Starter
keaton
keaton's Avatar
Ill have to check out that site then. Does the 510 have PA capabilities? One reason I want a cb. To yell at people outside.
My Rigs:
2000 XJ
2003 TJ
keaton is offline
post #11 of 19 Old 03-14-2009, 10:21 PM
sduncan
sduncan's Avatar
I don't think the 510 has PA capability. Look at the 520 or 530. They are only slightly higher in price from what I saw. I did a google search. I just looked a min ago. The 520 has PA.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #12 of 19 Old 03-14-2009, 10:26 PM Thread Starter
keaton
keaton's Avatar
Alright thats what i had thought. The trucker store.com has good prices on stuff too. Gonna go through them for all the other stuff i need. And get a radio off ebay like you did.
I guess it kinda comes down to preference when it comes to brands? I have always been lookin at Uniden but is Cobra really any better?
My Rigs:
2000 XJ
2003 TJ
keaton is offline
post #13 of 19 Old 03-14-2009, 10:42 PM
fedrusion
You may find you dont get very good performance with the antenna that low, ideally you should have about 1ft of antenna above the roofline. However with the top off you will probably be fine.
post #14 of 19 Old 03-14-2009, 10:44 PM
sduncan
sduncan's Avatar
I had bids on both but won the Uniden. Either one will be fine.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #15 of 19 Old 03-14-2009, 10:48 PM
sduncan
sduncan's Avatar
I am going to make a custom mount for it so I can make it so that a small amount can be over the top. Its just gotta clear the garage door.
'98 TJ, 5.7 HEMI,
sduncan is offline
Look at this price on BFG mts JGoad2 Tires & Wheels 6 08-16-2007 11:32 AM
Tire and rim package price question: good price? commodog Tires & Wheels 13 03-03-2007 08:51 PM
TIG price skip3 Fabrication Shop 5 01-12-2007 05:06 AM
best price J Mo Tires & Wheels 5 03-24-2004 12:36 AM
