CB Mounting in a JK 2door - JeepForum.com
 3Likes
  • 2 Post By Kruzin
  • 1 Post By cranbiz
post #1 of 5 Old 05-29-2020, 08:56 PM Thread Starter
nikkijp
nikkijp's Avatar
Jk CB Mounting in a JK 2door
Where are people mounting their CB in their 2 door JKs?
nikkijp is offline
post #2 of 5 Old 05-29-2020, 09:20 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
There are many mounts on the market. Some mount on the side of the center console, some mount above the rear view mirror. It's all a matter of personal preference.
I used Quadratec's quick-release bracket on the side of the console.
nikkijp and downs like this.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 5 Old 06-03-2020, 01:04 PM
cranbiz
cranbiz's Avatar
Rugged Ridge bracket over the mirror was where I mounted a full size CB and a dual band ham rig.
Now I have a Cobra 75WXST that is mounted in the overhead tray of my cage and the Ham rig is mounted under the dash with the remote head up on the cage.
downs likes this.
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #4 of 5 Old 06-05-2020, 09:19 PM
campingDan
When i had my JK , i had mine mounted above rear view mirror. Used L brackets and rubber coated wire hangers on the U shaped metal bracket by top. Easy to hide wire behind trim.
Sent from my SM-G975U using Tapatalk
campingDan is offline
post #5 of 5 Old 06-08-2020, 02:55 PM
prerunner1982
prerunner1982's Avatar
1993 XJ Cherokee
The Cobra 75 is quite popular with many of the local JK/JL Wrangler owners. The box is typically mounted under the passenger side of the dash with the mic run out from under/behind the dash and clipped near the center console/dash/grab bar for easy access. The power wires can easily be run through a foam filled pass through just behind the end of the dash right to the battery and an external speaker can easily be ran behind the trim pieces up between the visor and rear view mirror.
Jon
1993 XJ Sport 2 door
prerunner1982 is offline
