Can't set the correct time on 2003 Rubi?? - JeepForum.com
post #1 of 3 Old 12-01-2017, 05:11 PM Thread Starter
JimPet
Hi Guys:
I swear my 2003 Rubi is haunted. I replaced the Fog Light switch and everything on that end is working fine. I installed new bulb for my dull headlight. Played with the actuator door motor and fixed the no heat problem. Before I changed the switch I disconnected the positive feed to the battery, it was almost dead because fog lights were coming on by themselves because of faulty switch. I left the negative feed connected and disconnected the positive feed terminal from the Jeep. I put a battery tender on the positive terminal of the battery and with the negative line still hooked up put the negative terminal to connected battery tender negative lead. After a day battery came to full charge.
Today I went to put in the correct time on the radio face. It will not change the hours or minutes when I push the time button and insert pin point in HRS or MIN point section to change the time. Any suggestions?
Jim P.
JimPet is offline
post #2 of 3 Old 12-01-2017, 05:19 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Thought you were talking about engine timing at first, moved to the audio & stereo section for you.
Jerry Bransford is offline
post #3 of 3 Old 12-02-2017, 04:18 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Buy a new head unit to replace that ancient one.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Originally Posted by Jerry Bransford View Post
I'd rather knock myself unconscious, cut a finger off, poke my eye out with a sharp stick or be forced to go back to work than install anything made by Rusty's.
03' Rubicon/Zone 4.25" combo lift/Rancho 9000XL shocks/5.13 gears-35" MTZs/BM brakes
99' XJ on 33s. #18
TheBoogieman is offline
