Any hams on here? - JeepForum.com
post #1 of 32 Old 10-06-2007, 07:04 PM Thread Starter
zpedrick
Any hams on here?
I'm looking to put a "real antenna" on the jeep for 2m/70cm. Right now I've got a mag-mount on there and it is horrible . I miss my Radial/Larsen with RG-400 (high quality coax). Basically, I'm wondering if anyone on here has mounted their antenna(s) by more semi-permanent means. And if so, where. I'm looking to get this antenna up as high as I can. I thought about mounting it at the top of the windshield, but I worry about it's durability on trails in the woods. I'd go with a cowl mount, but I'd like to keep the antenna in the center for a non-directional setup if at all possible. Any ideas? Pictures of your rigs would be nice. Thanks in advance, KC2PHO.
zpedrick is offline
post #2 of 32 Old 10-06-2007, 07:37 PM
LTDan
LTDan's Avatar
I'm in the same boat with ya, I've got mine mag mounted to the rear bumper and it stinks. I'm looking at the mount that mounts to the spare tire bolts and then raises up to around the 3rd brake light level. The link is on here somewhere I'll see if I can find it again. KW4WKE
-edit- Couldn't find the thread but found the website:
http://www.arizonarockyroad.com/
Low Output 4 Cylinder Jeep Club #2001
Hers: 2004 WJ 4.0L, Bright Silver
LTDan is offline
post #3 of 32 Old 10-06-2007, 09:14 PM
Stu Olson
Stu Olson's Avatar
I've got a couple of permanent mounts on my TJ.....they seem to work equally well.
passenger rear corner....mounted on my side slider
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #4 of 32 Old 10-06-2007, 09:51 PM Thread Starter
zpedrick
AWESOME!!! Thanks for the pics too. I'm not sure how I want to do it just yet. I could weld up a bracker like the one from Arizona Rocky Road (or buy it), or use an nmo-k mount on the front fender. (decisions decisions.......) I'm leaning more towards the mount in the rear, only because I think I may go with a 440 5/8 wave and 2m 5/8 wave. I can hit a lot of repeaters, but there's some that only trip the squelch and I know that with better antennas I could get into them. Also, I will be adding some 900mhz gear soon, which I may put on the front.
zpedrick is offline
post #5 of 32 Old 10-06-2007, 10:03 PM Thread Starter
zpedrick
Did you type that callsign correctly? I went to look you up on qrz.com and it says it's not in the database. Just wondering what class you were.
zpedrick is offline
post #6 of 32 Old 10-06-2007, 10:05 PM
Stu Olson
Stu Olson's Avatar
Some other links to some of the radio equipment I've had in my TJ....
http://www.stu-offroad.com/misc.asp
Stu Olson
ARB Locked & Loaded
post #7 of 32 Old 10-06-2007, 10:19 PM
matt1751
Junior Member
Hi. I haven't mounted any radios in my TJ yet and not sure if I will but If I did I was going to get one of those Cb antenna mounts that go behind the drivers side tail light and just drill out the hole to 3/4 so I could mount a NMO mount and cable. N2LFD
2002 TJ
2004 F250 PSD
1977 GMC Ambulance
2005 kawasaki Brute Force 750
matt1751 is offline
post #8 of 32 Old 10-06-2007, 10:26 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Got a small square rod from Lowes or Home Depot. Drill and mount to the side of spare tire mount.
2009 JK Rubicon. 2019 Mustang GT 6 Spd DD
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine, LCA & Evap Skid; Rock Hard Gas Tank Skid; Warn Stainless Diff Skids, Uniden 520XL CB, Aeroforce Interceptor, Valentine 1, Baja Designs Squadron-R Pro Fog Pocket.
Ouray - TJ-8/07
Moab - TJ: 4/06, 5/08, JK: 4/09, 5/11, 4/13, 5/16, 4/17, 5/18
Rubicon - TJ-9/08
Pics at
Thunderstrike is offline
post #9 of 32 Old 10-06-2007, 10:57 PM Thread Starter
zpedrick
Perfect. Stu, nice site. Now I just have to buy my antennas. I'm going to look for a commercial grade 5/8th wave 2m and 440 antenna (2 separate antennas obviously). Any recommendations? I'll probably use the dual bander antenna I already have for aprs or something.
zpedrick is offline
post #10 of 32 Old 10-07-2007, 06:54 AM
slo9fo5oh
You sir,(Stu) you must stay drunk all the time from everyone buying you a beer for your help/assistance through your website.... I have to say, I owe you a couple, THANKS!!!!!
slo9fo5oh is offline
post #11 of 32 Old 10-07-2007, 09:26 AM
Stu Olson
Stu Olson's Avatar
I have, over the past 15+ years, bought my mobile antennas from HRO. We have a local outlet here in Phoenix but buy them online is just as easy. I've had great luck with a variety of Diamond dual band antennas although other similarly priced brands have done equally well.
For the area I wheel in, I've found a 3' long dual band antenna to be pretty much the optimum setup. For a 2m/440 antenna in this length, I get reasonable gain but it doesn't make for a tree branch "grabber" on the tail. We have lots of overhanging brush and I've seen longer antennas get tangled up in them damage the antenna and/or mount.
That little 18" long dual band whip (in the 1st photo) on my front fender has survived years of abuse. Its very flexible nature has contributed greatly, that I am sure. It does lack good gain but if I need something just for the trail that day, or for running around town where repeater coverage is usually quite good, it does the job just fine.
Hope this helps a bit.
Stu Olson
ARB Locked & Loaded
post #12 of 32 Old 10-07-2007, 09:29 AM
Stu Olson
Stu Olson's Avatar
If only it were so.
Interestingly enough, if I were to receive just $1 from each visitor that used my site on any particular month, I could easily purchase a new Rubicon every month and mod it into a nice rig to boot. Unfortunately, that hasn't happened yet. Maybe some month it will
Stu Olson
ARB Locked & Loaded
post #13 of 32 Old 10-07-2007, 10:08 AM
Chris @ GATR
Chris @ GATR's Avatar
You are aware that there is a forum just for radio and electronis talk, correct?
Got ignorance? Please see below.
Originally Posted by kd4yor View Post
Chris, I just think your having buyers remorse for all the work in your 8.8 for no added gain (over the Dana 35).
Chris @ GATR is offline
post #14 of 32 Old 10-07-2007, 12:24 PM Thread Starter
zpedrick
I am now, thanks.
zpedrick is offline
post #15 of 32 Old 10-07-2007, 01:05 PM
matt1751
Junior Member
I sell commercial grade antenna's.. I will send you a PM with my info as i'm in NJ also,, I run a 5/8wave dual band antenna on my truck that works well.
matt
N2LFD
2002 TJ
2004 F250 PSD
1977 GMC Ambulance
matt1751 is offline
Calling fellow hams with FT-857's in their heeps heyitsme Audio, CB & Ham Radios, GPS, & Electrical 0 09-07-2008 08:58 PM
Calling All Mobile HF Hams... SpeedyCat3 Audio, CB & Ham Radios, GPS, & Electrical 27 02-15-2008 06:47 AM
Any HAMs here? Malpaso Audio, CB & Ham Radios, GPS, & Electrical 18 04-13-2007 05:10 PM
You Guys with Remote Head HAMs jmcbroom2 Audio, CB & Ham Radios, GPS, & Electrical 14 03-19-2007 11:24 AM
Hams, have you picked up the space suit signal from ISS? Jerry Bransford Audio, CB & Ham Radios, GPS, & Electrical 6 02-09-2006 04:03 PM
