Airbag Wire harness under drivers seat - JeepForum.com
 3Likes
  • 1 Post By CJ7-Tim
  • 1 Post By ravenworks
  • 1 Post By Jerry Bransford
post #1 of 10 Old 12-25-2016, 10:35 AM Thread Starter
gcstraub68
2009 JK Wrangler
I have a small problem, my new 3 mo old puppy didn't like being left in the jeep and has sabotaged my airbag system. Under the drivers seat is the wire harness he has chewed one of the wires through and chewed several others. My airbag light is now lit all the time but no warning sound.
how difficult is it to replace this coming from the seat? how do I find out the part number short of calling the dealership? I am a do it yourself kind of guy but I am not finding the harness listed anywhere other than an new seat. Any help is appreciated.
gcstraub68 is offline
post #2 of 10 Old 12-25-2016, 11:14 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
It's only some wires, use the appropriate size wire if necessary, and/or just solder them back together. Disconnect the battery and wait 20 minutes to render the airbag system safe to work on. A new wire harness will likely cost several hundred dollars from the Dealership.
gcstraub68 likes this.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #3 of 10 Old 12-25-2016, 11:15 AM
ravenworks
ravenworks's Avatar
Why not just cut it open and solder in splices?
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #4 of 10 Old 12-25-2016, 01:12 PM Thread Starter
gcstraub68
2009 JK Wrangler
Thanks Tim, that was what I was hoping was the suggestion.
post #5 of 10 Old 12-28-2016, 02:04 PM
digdug18
Replace the harness, don't solder on those wires. The system checks for resistance faults in the wiring harness as a pre-check. The airbag is a safety system that I wouldn't want to fail instead of deploying Or for it to accidentally deploy when my kid or me was driving.
This is in the spend the money and do it right the first time category.
digdug18 is offline
post #6 of 10 Old 12-28-2016, 04:37 PM
CJ7-Tim
CJ7-Tim's Avatar
Wondering how a solder joint will alter the resistance enough (any ?) to trigger an Air Bag fault ?
Since the air bag system is self testing, it will either be just fine, or will not work and will light the air bag fault lamp. There is no such thing as accidental air bag deployment from excess resistance.
- Benjamin Franklin
CJ7-Tim is offline
post #7 of 10 Old 12-29-2016, 01:47 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
A properly installed splice is undetectable.
Jerry Bransford is offline
post #8 of 10 Old 12-30-2016, 08:43 AM Thread Starter
gcstraub68
2009 JK Wrangler
Thanks to all for the advice, to the point of adding resistance, I am not sure the solder would do that or not. However, my thought would be to instead of solder the wire use simple wire connectors and crimp the wires and connection, then re-wrap the harness and hide it up and away from the puppy. Thoughts?
post #9 of 10 Old 12-30-2016, 11:23 AM
Jerry Bransford
Administrator
Electronic circuits are held together with solder, it works well enough that it has gone to the moon many times and keeps our computers working and aircraft flying.
Twist the wires solidly together so they have mechanical strength between them. That is what provides the solid connection, not the solder. Solder the twist with enough heat that the solder flows easily and completely into and through the splice. Heat the joint up with the soldering iron on one side enough so the solder melts when held against the joint on the other side. Don't try to melt the solder on the iron and let it drip onto the joint which will produce a cold/bad solder joint. Tape the splice up good or use heat-shrink insulating tubing afterward and you're done.
ravenworks likes this.
post #10 of 10 Old 12-31-2016, 05:17 AM
ravenworks
ravenworks's Avatar
Pretty much what I was going to say.
Semper-Fi "81-84"
I.U.O.E. - 18
