Advancing Odometer - JeepForum.com
 3Likes
  • 1 Post By gutthans
  • 1 Post By Kruzin
  • 1 Post By jp360cj
post #1 of 5 Old 07-19-2019, 08:23 AM Thread Starter
cmeflygtp
cmeflygtp's Avatar
Advancing Odometer
So, I bought a new Odometer for my Ď83 CJ7 and would like to advance the mileage to be true. I have searched online to no avail, does anyone know how I can add mileage to the new odometer?
Sent from my iPhone using Tapatalk
cmeflygtp is offline
post #2 of 5 Old 07-19-2019, 08:45 AM
gutthans
gutthans's Avatar
Well, the way I have done it was with a rotary drill.
Using an old piece of speedometer cabling (about 8 - 10"), insert the drive end into the speedometer and the cut-off end into the drill chuck. Crank the drill up to a few hundred rpm and use the thumb lock to lock the speed. Go have lunch...
This takes a while, depending on the drill speed. I don't know how many rpms a speedo gear can tolerate, so there's probably a limit on how fast you can click off the mileage, but it works in both directions to add or remove. Don't know if there's a faster way.
cmeflygtp likes this.
gutthans is offline
post #3 of 5 Old 07-19-2019, 08:45 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
They're made so you can't change the mileage on them without pretty much destroying them taking the case apart. Changing/tampering with mileage on odometers is technically against the law. What you're 'supposed' to do is contact your local DMV and they will usually note the odometer change on the title, or tag it as unknown mileage.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 5 Old 07-19-2019, 09:01 AM Thread Starter
cmeflygtp
cmeflygtp's Avatar
Thanks!
@Kruzan I get that which is actually one of the reasons I wanted to advance the new Odometer to the proper mileage.
post #5 of 5 Old 07-28-2019, 08:30 PM
jp360cj
1977 CJ7
Here are the instructions (pg 3) for advancing the speedometer. Sounds pretty in depth to remove the odometer from the cluster. http://oljeep.com/gw/82_tsm/Part%203%20Section%20C.pdf
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
