4 Channel Amp Install Issues. - JeepForum.com
post #1 of 4 Old 07-28-2014, 08:50 AM Thread Starter
nscharich
2007 WK
I have been trying to install a 4 Channel amp in the back compartment of my jeep grand cherokee 2007. I ran all the wires back there and the amp fires up fine and works when I hook it up with lead wire when its outside the door. However, i would like to use the stock wiring in the jeep so i do not have to take the boots off the doors. So I ran back signal RCA's from my aftermarket radio (4 channels) and then I ran up speaker wire that I thought I could tap into the wiring harness after it is being powered by the amp. But I did that and nothing was working. I do not have the Boston Acoustics radio and or navigation so I do not have a factory Amp i need to bypass. I was wondering if it has something to do with the jeep having 6 speakers or something. I am really confused at the moment.
nscharich is offline
post #2 of 4 Old 07-28-2014, 09:14 AM
kingcat400
Did you unhook the wires from the output of the radio? or just tap them?
By 6 speakers do you mean 6 speakers or 4 speakers and 2 tweeters. there is probably a amp somewhere if there are 6 speakers.
the easiest way is to connect the wires right before the boot or just run new wire.
kingcat400 is offline
post #3 of 4 Old 07-28-2014, 09:23 AM Thread Starter
nscharich
2007 WK
Yea I unhooked the wires from the radio and made sure they were just going into the speakers
Yes, by 6 speakers the jeep has 2 tweeters. I have no idea where the amp is.
There has to be another way to do it. Someone has to know where the amp/if there is an amp in the car.
post #4 of 4 Old 08-02-2014, 09:46 AM
mrjaydeeone
2007 WK
do you have a boston acoustics stock system? you can tell by looking at front door speakers, there should be a badge on the grill stating Boston acoustics if so. Anyways taken from wkjeeps.com
stock amp is behind panel on drivers side in the cargo area
http://wkjeeps.com/interior_trim.htm#QUARTER
Current 2007 WK Graystone Pearl V8 4.7 limited fully loaded. Current mods Escort 9500 IX tapped into rearview mirror and mounted under mirror with bicycle reflector bracket. 6K HIDs in Lows and 3K HIDs in Fogs
mrjaydeeone is offline
amplifier , amplifier location , audio components , sound system , speakers
