2012 JK Infinity Audio problems - JeepForum.com
post #1 of 1 Old 05-19-2019, 12:21 PM Thread Starter
[email protected]
Hello everyone. I am new to the forum and need some help with my stereo upgrade. I have listed all the equipment I have installed and how I set it up. I appreciate any help anyone can give me.
2012 Jeep Wrangler Sahara 2 Door
Infinity sound system with sub, no touchscreen
The factory head unit and amplifier is being used. I did not upgrade them. The factory tweeters are disconnected and not in use. I have installed an audio control LC6i line output converter, a pioneer GM-D9705 5 channel amplifier, and alpines spe-6000 4 ohm woofers. The subwoofer is a cheaper dual voice coil 4 ohm 8in bazooka. I have wired the LOC after the factory amplifier using Mesa 16 gauge speaker wire. The LOC is then connected to the amplifier via Messa rca cables. The Each set of speakers has a separate channel. The alpine woofers are ran in stereo, while the bazooka subwoofer is bridged to 2 ohms. I have used the factory speaker wires. I have also stuffed all 5 speaker enclosures with foam.
My problem is the midrange alpines sound very distorted at mid to high volume. They sound worse then the factory setup. At 75% volume with the gain all the way down, the speakers sound very poor and static. I have tried setting the amp with and without the hi pass filters on. I have adjusted the frequency of these channels every way possible. The gain is turned nearly all the way down. I can not figure out why I am not getting clear sound from my speakers.
Can anyone offer any insight on this? Do I need to replace the factory head unit and remove the factory amp? The factory amp and head unit communicate via canbus and cannot be separated. Could the factory speaker wire cause this? When the sound system was stock, it did not sound bad, just not great. It certainly was not this distorted. Any help or input is greatly appreciated!
2012 Grand Cherokee problems bry578 WK2 Grand Cherokee Forum 6 04-24-2019 06:35 AM
2012 Liberty wiper problems Plugger41 KK Liberty Forum 0 11-21-2018 11:28 AM
Infinity Sound System 95 ZJ with Kenwood radio. muddflow ZJ Grand Cherokee Forum 39 10-25-2018 09:54 AM
Audio problems after Uconnect update 17.43.01. Help!! CdnJeepGC WK2 Grand Cherokee Forum 2 07-30-2018 08:13 PM
Clicking and stalling problems 2012 grand cherokee larado ericamcdonald20 WK2 Grand Cherokee Forum 6 06-30-2018 10:28 AM
