2008 Jeep Grand Cherokee Diesel with alternator working intermittently - JeepForum.com
post #1 of 5 Old 02-17-2019, 12:30 AM Thread Starter
R2esteves
I have a 2008 Jeep Grand Cherokee diesel engine.
A couple of months ago, the alternator quit working and a new alternator was installed by a professional (not at a Chrysler dealer). At the same time, a new battery was also purchased and installed.
Since then, new alternator works intermittently. I've plugged a voltmeter and it may read 14.7 for a day or two and then goes down to 11.2, 11.3 at which point I stop driving the car.
After a few days without driving the car, and after charging the battery with a home battery charger, when starting the car the voltmeter reads again 14.7, 14.8. Again 24 hours later, it goes down to 11. something.
The new alternator was checked and it is not damaged. There is a new battery, so what might be causing this issue?
A mechanic mentioned that it might be a software issue between the mercedes software and the Chrysler software.
Any thoughts will be appreciated.
Thanks
R2esteves is offline
post #2 of 5 Old 03-03-2019, 09:35 PM
Gc23
Gc23's Avatar
Where are you testing it at the alternator terminal or battery posts?
Gc23 is offline
post #3 of 5 Old 03-03-2019, 09:39 PM
Gc23
Gc23's Avatar
bad alternator try smelling it while your down there with your leads might as well right I smell stuff sometimes when itsbad
Gc23 is offline
post #4 of 5 Old 03-03-2019, 09:53 PM
mukluk
mukluk's Avatar
Check for stored trouble codes using a scanner. Normally in the case of a charging system fault, the computer should throw a fault code which can be a useful starting point to figure out what the problem is.
The other thing that can help in cases such as this is to ensure all your battery cable connections (at both ends of the cables) are clean and tight, along with the electrical connections going to the alternator and power distribution box in the engine bay.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #5 of 5 Old 03-03-2019, 10:10 PM
Gc23
Gc23's Avatar
Or did he even replace the alternator unfortunately that’s something to take into consideration. I hate taking my stuff to get fixed
Gc23 is offline
alternator
Official JL Wrangler Picture Thread SKT JL Wrangler Technical Forum 842 03-01-2020 08:24 PM
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3864 10-19-2019 10:58 PM
Diesel 3.0 Engine Head engine with Cams and Valves Sprinter Jeep Mercedes Benz Tango. Drivetrain 0 12-19-2018 03:46 AM
2008 Jeep WK 3.0 CRD Diesel wheel speed sensor causing other codes? Sosasser WK Grand Cherokee & XK Commander Forum 4 07-24-2018 09:22 AM
How to install an RB1 navigation unit in a 1997-2001 Jeep Cherokee Country Jeep XJ Cherokee Technical Forum 14 01-21-2018 04:43 PM
