Sudden change in handling/feel on freeway - JeepForum.com
post #1 of 2 Old 09-17-2021, 02:53 PM Thread Starter
Smjbronco
I have a 2020 GC with 7k miles. I recently noticed a”floating” or “swaying” feeling when driving at high speeds. It drives straight without any corrections needed. I hadn’t felt this before so I took it to the dealership and they looked at the suspension and steering but found nothing wrong. Any ideas what might be causing this.
Smjbronco is offline
post #2 of 2 Old 09-17-2021, 10:58 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Are you hauling heavier loads, change in tire pressure? Some tires will have a different feel after some wear, as the corners wear. Rotation sometimes helps. Did the dealer check alignment?
I would put a couple more psi into the tires and see if it makes a difference.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
