Snobrdrkid's 04 Overland Build Thread - Page 41 - JeepForum.com
 13Likes
post #601 of 617 Old 10-06-2021, 04:35 PM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Yeah, that is the plan!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #602 of 617 Old 10-10-2021, 02:24 PM Thread Starter
snobrdrkid07
Anyone have ideas to keep the coolant and oil temperatures under control? Towing this weekend I'm seeing coolant at 215 to 225. Oil between 220 and 230
Coolant temperature is being digitally read from the automatic climate control display.
Oil temperature is being measured from a sensor between the engine and oil filter.
Transmission has been staying between 160 and 180 pan temperature.
I watched a video on how to modify the hydraulic fan solenoid to get the fan to spin faster. I might pick up a spare solenoid and try that.
With a factory 195 thermostat and a brand new Mopar water pump and a newer Mopar radiator there's no reason temperatures should be this high.
-Michael-
post #603 of 617 Old 10-19-2021, 06:44 AM
leadsled jeep
leadsled jeep's Avatar
What speed were you moving at when temps increased? What radiator you using also? Fan upgrade may not help if you were at highway speed. Really shouldn’t need a fan there much at all anyway.
For a WEAK and IGNORANT sheople, SERF-dom is a Reward, not a Curse. W1CCW
leadsled jeep is offline
post #604 of 617 Old 10-19-2021, 07:25 AM Thread Starter
snobrdrkid07
I was towing between 65-80 mph depending on traffic.
Mopar radiator and water pump.
-Michael-
post #605 of 617 Old 10-20-2021, 08:15 AM
leadsled jeep
That’s fast enough where a fan really shouldn’t be required for air velocity through the radiator. I don’t think it’s your fan.
post #606 of 617 Old 10-20-2021, 08:55 AM Thread Starter
snobrdrkid07
I wish there was a quality high flow water pump and quality aluminum radiator for the WJ.
Unless this isn't "normal"
-Michael-
post #607 of 617 Old 10-21-2021, 05:09 AM
leadsled jeep
I installed a cheap all aluminum one from China about two years ago. It’s been flawless and is a bit larger than the stock size. It fit with only a few small modifications. I posted on it here of course.
Another thing you can do to help is block the airflow around your radiator - make sure all frontal air is coming thru the fins and not around the tank.
post #608 of 617 Old 10-21-2021, 05:22 AM
leadsled jeep
Here’s the thread if you’ve not read it.
https://www.jeepforum.com/forum/f310...rs-ok-4240074/
Have you verified your thermostat opens ALL the way? I once had one fail on me and it cost me an engine. Now I ALWAYS check a stat in slowly heating up water on the stove before I install it. Make sure it opens up at the right temp fully. Also maybe get a high flow thermostat. I have one on my Mustang. I can find the brand if needed.
post #609 of 617 Old 10-21-2021, 06:52 AM Thread Starter
snobrdrkid07
Thanks for linking those post. A lot of good info there.
Hesitant to replace already if it's not leaking. This Mopar unit is fairly new. But check in the thermostat maybe a good option as well.
On another note. This weird rough idol seems to be getting worse. Maybe need to pull a spark plug
-Michael-
post #610 of 617 Old 10-21-2021, 04:59 PM
leadsled jeep
This is the type of high flow thermostat I used on my Mustang when temps became an issue. It flows much more which you can see when you test it in the slow boil stove top. Be sure to use a thermometer so you know the temp each opens at. Run your current and the new replacement in the same pot at the same time.
https://www.holley.com/products/cool...ontent=Cooling
post #611 of 617 Old 10-21-2021, 05:02 PM
leadsled jeep
That’s likely not for the Jeep but it was a picture of the style so I grabbed the link.
post #612 of 617 Old 10-21-2021, 05:26 PM
leadsled jeep
Sorry to keep posting but did you read this thread on towing?
https://www.jeepforum.com/forum/f310...oo-hot-430453/
post #613 of 617 Old 10-22-2021, 11:22 AM Thread Starter
snobrdrkid07
The boat uses those style thermostats in the motors. The work well, they keep the motors at 170 under load. 160 degree thermostat.
As far as that thread, I just read through it. I would be really upset if my new Mopar Radiator was bad. ~2 years old, with a new water pump, mopar, couple months, and G-05 coolant.
-Michael-
post #614 of 617 Old 10-23-2021, 06:27 AM
leadsled jeep
I was getting about 55k miles on a stock radiator before the seal on the plastic tank would fail. I’d say your thermostat function might be the best first place to check.
post #615 of 617 Old 10-25-2021, 02:31 PM
leadsled jeep
Any update? Inquiring minds you know…..
