Officially works: 6.4 SRT in a WJ - JeepForum.com
 14Likes
post #1 of 57 Old 09-12-2017, 06:05 PM Thread Starter
ilikejeepssrt8
Ok so to start off, it is not completely done (projects never are) nor is it perfect. But I can say that I have a 2001 WJ that runs and drives powered by a 2015 srt 6.4
I have researched the topic for a long time (hemi vs WJ) and I had the right jeep at the right time come up so I decided to go for it.
It started out life as a 4.7L limited. With the select track transfer case and the 44 limited slip rear end. (3.73 I think they are all that ratio) 545rfe trans.
Steps taken:
Remove old engine
Service all remaining parts of the drivetrain (all seemed in good shape)
Figure out if it even fit (it does basically same dimensions as a 4.7
Bolt to original trans, Center and angle combo to achieve proper working angles on u joints
Fab and mount new engine mounts
Cut, notch, and box in rs frame to fit alt
Fabricated new exhaust
Removed all mocked up parts fully welded and painted
Wired new engine and installed
Installed electric fans with stand a lone controller to original rad
Installed remote filter mount to clear steering and track bar.
Hardships:
Engine mounts. Bought universal hemi mount kit from trans dapt and proceeded to cut them up untill they would work. Also needed to make intermediate plates. Drivers side mount went forward and passenger side went backwards.
Exhaust. Obviously no one makes headers or an exhaust kit for it so I bought a set of shorty headers for a gen 1 hemi and.... proceeded to cut them up u till they worked. Flange from the new hemi manifolds. Changed primary tube angle, oh and for the drivers side I had to cut the whole thing apart and change it's angle to get around the front diff. Then the rest was a cheap do it yourself 3" summit kit with a magnaflow muffler.
Electrical harness: well this wasn't really a hardship. A company called HOTWIRE AUTO. Called them. I have this engine and I'm putting it in this. Done
Oil pan: engine was from a challenger and had a front sump. Got a pan and oil pick up from a 14 ram with a 6.4
Cost:
6.4 on eBay $3600
Jeep $200
Complete harness $1000
Computer tuning $500
Rad fan set up $500
Those are the big ones. Other misc stuff was easily another 1500.
Pics
20170408_122343_1505255342316.jpg   20170411_143212_1505257385543.jpg   20170411_144634_1505257405566.jpg   20170411_145325_1505257435973.jpg   20170411_165142_1505257466958.jpg
CJREX, mudbear and Sociopath like this.
ilikejeepssrt8 is offline
post #2 of 57 Old 09-12-2017, 06:12 PM Thread Starter
ilikejeepssrt8
More pics
20170501_113037_1505257568729.jpg   20170501_113058_1505257622885.jpg   20170514_114833_1505257657680.jpg   20170514_122944_1505257683063.jpg   20170514_162338_1505257704795.jpg
20170628_190246_1505257756277.jpg   20170702_155034_1505257798775.jpg   20170703_142654_1505257838016.jpg   20170703_144339_1505257870273.jpg   20170715_162205_1505257905221.jpg
mudbear likes this.
post #3 of 57 Old 09-12-2017, 06:17 PM Thread Starter
ilikejeepssrt8
More
mudbear likes this.
post #4 of 57 Old 09-12-2017, 06:22 PM Thread Starter
ilikejeepssrt8
More pics 3
20170728_170319_1505258329772.jpg   20170728_163044_1505258354272.jpg   20170728_154930_1505258383380.jpg   20170727_185651_1505258407345.jpg   20170723_174523_1505258429594.jpg
20170730_171741_1505258465499.jpg   20170730_171939_1505258500302.jpg   20170730_171851_1505258532584.jpg
mudbear likes this.
post #5 of 57 Old 09-12-2017, 06:25 PM Thread Starter
ilikejeepssrt8
More pics 4
20170802_205134_1505258589983.jpg   20170812_183112_1505258645851.jpg   20170813_162647_1505258681279.jpg   20170905_103453_1505258710053.jpg   20170905_103431_1505258731318.jpg
mudbear, Grippy0 and GCZJ93 like this.
post #6 of 57 Old 09-12-2017, 06:28 PM Thread Starter
ilikejeepssrt8
That's it that's all additional info to anyone wanting to know more info apon request
post #7 of 57 Old 09-13-2017, 03:54 AM
Grippy0
Top work mate, this will give the wj a good kick in the guts
Grippy0 is offline
post #8 of 57 Old 09-13-2017, 10:28 AM
tymaoaretae
tymaoaretae's Avatar
2003 WJ
That is awesome. I always hoped someone would succeed with this and it wouldn't be as bad or expensive as everyone speculated. Nice job.
And your cost is close enough to a remanufactured 4.7 that I'd consider this if mine kicked the bucket.
2003 WJ LTD 4.7, 242HD, PR44+ARB+RCV & D44HD+varilok+BTF 4.56, 7" RC LA (Clayton coils + pucks), Bilstein 5165, OBA, Lizardskined & Monstalined inside.
tymaoaretae is offline
post #9 of 57 Old 09-13-2017, 10:32 AM Thread Starter
ilikejeepssrt8
I mean I lucked out with finding that 6.4 I can see it being alot more money and time consuming to get one.
post #10 of 57 Old 09-13-2017, 10:43 AM
tybarious
tybarious's Avatar
Any videos of it running and driving around?
tybarious is offline
post #11 of 57 Old 09-13-2017, 11:00 AM Thread Starter
ilikejeepssrt8
I do have videos of it running but it won't upload. Or maybe I just don't know the right way to do it. As for driving around I am waiting on a new set of springs for the front end so the axle is on the ground right now
post #12 of 57 Old 09-13-2017, 11:33 AM
tybarious
tybarious's Avatar
Might try uploading to youtube and posting a link.
post #13 of 57 Old 09-13-2017, 01:02 PM
Jeeples
Harsh, but fair
Jeeples's Avatar
The biggest thing I'm excited about is that it fits without a ton of modification to the WJ chassis and is a viable swap.
The 5.7/6.1/6.4 are all dimensionally the same, I can see the 5.7 being a perfectly budget friendly swap compared to a quality reman'd 4.7. The 5.7 can be had for significantly cheaper than the 6.1 or 6.4 motors, although they're not as cheap as an LS 4.8/5.3/6.0, this certainly shows that you can upgrade the WJ powertrain significantly and keep it Mopar at the same time.
There's several listings on Ebay for low mileage (under 50K) 5.7 truck motors for $2500 or less and some with free shipping.
I will certainly be considering a 5.7 swap when my 4.7 finally kicks the bucket or when I can find a screaming deal on a good 5.7 donor (think $1k or less) to swap in.
@ilikejeepssrt8
I'm assuming you left the BCM in place? Aside from the gauges, what doesn't work on the interior, if anything?
What about the SKIM and new PCM? What was needed to make them cooperate or did you have the SKIM flashed out of the 6.4 PCM?
The earlier WJ 545RFE uses a standalone TCM, did you retain that or is TCM function now handled by the 6.4 PCM?
I'm assuming the 545RFE bolted right up to the 6.4, but I'm willing to bet you could swap in a newer 65RFE behind a 5.7 truck motor and have a 6 speed auto.
EDIT:
Any bets on when the first Hellcat swap happens?
Gone:
'00 Limited
'03 Laredo
Current
'14 Overland EcoDiesel
Old Jeeps never die, they just fade away.
Jeeples is offline
post #14 of 57 Old 09-13-2017, 01:13 PM Thread Starter
ilikejeepssrt8
BCM was left alone and everything still works as it should
Trans cal is in the new PCM
Wiring harness was made for my swap so it was all plug and play
All the security controls had to be flashed out
The new PCM I got from a junk yard from an 09 hemi ram
post #15 of 57 Old 09-13-2017, 01:14 PM Thread Starter
ilikejeepssrt8
Yes it bolts right up. Reused the torque and flex plate
