Help!!! - JeepForum.com
post #1 of 9 Old 04-29-2018, 11:52 AM Thread Starter
Leslielou77
Help!!!
So... I am no mechanic but my tranny went out in a 97 grand Cherokee laredo 4x4. I love my jeep. My dad and bro. Put a tranny out of a wrecked 96 in it. But now the tachometer wont go above 2 rpms and seems like it is not communicating when to change gears. New tranny seems very strong, check engine light is on too. This project broke me and I really need my jeep for work. Thanks in advance for any and all advice.
Leslielou77 is offline
post #2 of 9 Old 04-29-2018, 12:05 PM
jtec
jtec's Avatar
2014 JK Wrangler
well I would want to know
What was reason to replace old unit?
What is the code responsible for CEL?
jtec is online now
post #3 of 9 Old 04-29-2018, 12:19 PM Thread Starter
Leslielou77
Jtec, it stopped shifting and we changed the filter and fluid and it did not help, so we changed it. I am pretty sure the issue now has something to do with communication. Going to have codes read today after work.
post #4 of 9 Old 04-29-2018, 12:46 PM
jtec
jtec's Avatar
2014 JK Wrangler
Could it be the same issue - seams the trans had a quick diagnosis.
do yu know which trans 42 44 Re Rh
Did you ck TV cable ?
jtec is online now
post #5 of 9 Old 04-29-2018, 12:50 PM Thread Starter
Leslielou77
45rfe
post #6 of 9 Old 04-29-2018, 01:35 PM
jtec
jtec's Avatar
2014 JK Wrangler
I guessed it was a 4.0L : you sure 45RFE?
45RFE: A four speed automatic transmission was used in 1999 Jeep Grand Cherokees with 4.7L engines. Gear Ratios: 1st Gear: 3.00:1, 2nd Gear: 1.67:1, 3rd Gear: 1.00:1, 4th Gear: .75:1, Reverse Gear: 3.00:1
46RE: A four speed automatic transmission was used in 1998 Jeep Grand Cherokees with 5.9L engines. Gear Ratios: 1st Gear: 2.45:1, 2nd Gear: 1.45:1, 3rd Gear: 1.00:1, 4th Gear: .69:1, Reverse Gear: 2.20:1
44RE: A four speed automatic transmission was used in 1996 to 1998 Jeep Grand Cherokee's with 5.2L engines. Gear Ratios: 1st Gear: 2.74:1, 2nd Gear: 1.54:1, 3rd Gear: 1.00:1, 4th Gear: .69:1, Reverse Gear: 2.20:1
42RE: A four speed automatic transmission was used in 1993.3 to 1998 Jeep Grand Cherokees with 4.0L engines. Gear Ratios: 1st Gear: 2.74:1, 2nd Gear: 1.54:1, 3rd Gear: 1.00:1, 4th Gear: .69:1, Reverse Gear: 2.20:1
46RH: A four speed automatic transmission was used in 1993 to 1995 Jeep Grand Cherokees with 5.2L engines. Gear Ratios: 1st Gear: 2.45:1, 2nd Gear: 1.45:1, 3rd Gear: 1.00:1, 4th Gear: .69:1, Reverse Gear: 2.20:1
jtec is online now
post #7 of 9 Old 04-29-2018, 01:38 PM
jtec
jtec's Avatar
2014 JK Wrangler
Hopefully one of the detail guys will add info. Would be nice to know which model this is.
jtec is online now
post #8 of 9 Old 04-29-2018, 07:11 PM Thread Starter
Leslielou77
It is the 4.0 straight 6 out of a 96. U r right. Sorry. Code read transmission control relay
post #9 of 9 Old 04-29-2018, 07:26 PM Thread Starter
Leslielou77
42re
