Coolant Sensor Error? - JeepForum.com
post #1 of 9 Old 05-24-2010, 11:35 AM Thread Starter
stormer1092
2019 KL Cherokee
on my control pannel it keeps saying coolant sensor bad what does this do? and how can i fix it?
stormer1092 is offline
post #2 of 9 Old 05-24-2010, 12:05 PM
KHoff90
KHoff90's Avatar
Your coolant sensor is (probably) not bad. This is a well known issue with a solder joint in the VIC. Search and you will find write-ups on how to repair. Its a PITA. I just deal with mine..
Found this for you.
https://www.jeepforum.com/forum/f13/c...-fixed-175207/
1997 ZJ 4.0 - IRO 3.5" Lift. 31x10.5x15 M/Ts - Sold January 2011 :(
Steam: KHoff
PSN: KHoff128
KHoff90 is offline
post #3 of 9 Old 05-24-2010, 03:19 PM
indredsnake99
indredsnake99's Avatar
Thanks for posting the link KHoff90 I need to do that to my jeep
Wayne
1997 formerly GREEN now rustoleum bed lined zj 4.0 np242 bought 9/25/2008
gone
1998 5.9l platnium zj np249 k&n sct bought 4/6/2010
2007 sahara 2 door wrangler stock bought 02/08/2011
Originally Posted by ZJones View Post
You'll learn a lot. I didn't know anything when I first joined this site either. (not sure if that's changed at all :laugh:)
indredsnake99 is offline
post #4 of 9 Old 05-24-2010, 05:24 PM
CLNinja
CLNinja's Avatar
meh... i just replaced the coolant reservoir with a new one and the error went away, it was surprisingly cheap from the dealer, i think only like $20 for the entire reservoir with the sensor built in
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #5 of 9 Old 05-24-2010, 05:58 PM
cirame1
yea mines been doing it for a while. now i have the rear lamp failure... ugh
98' 5.9 slate on slate...
3.5" F>R swap, front and rear adj. track bars
17" rubicons w/ 285 70 17 inch hankook mtr's
full 3 inch exhaust w/flowmaster 40 series
242j tcase swap completed by jeeps unlimited providence,R.I.
cirame1 is offline
post #6 of 9 Old 05-24-2010, 11:05 PM
indredsnake99
i had the same failure the wierd thing was with the socket and bulb in the housing it did not work when i took the socket out it worked changed the bulb and the message went away
Wayne
gone
post #7 of 9 Old 05-25-2010, 01:31 PM
jeep360limited
jeep360limited's Avatar
2003
i just deal with mine, just make sure you have enough coolant every once in a while and you should be good.
Charlie
2003 Ford Ranger Edge
1986 Jeep CJ7
1998 Jeep Grand Cherokee 5.9 Limited-----SOLD
jeep360limited is offline
post #8 of 9 Old 05-26-2010, 03:22 AM
KHoff90
KHoff90's Avatar
No problem. I do too, I'm just too lazy
Steam: KHoff
PSN: KHoff128
KHoff90 is offline
post #9 of 9 Old 05-26-2010, 03:39 AM
sadass
sadass's Avatar
I have be getting a coolant sensor error on my Vic, It is intermittent . this is different then the coolant low level error that the Vic will display if the level is low. Now which one are you guy talking about . sound like half are referring to the level and the other half the temp sensor.
There are two different sensors , one in the reservoir and one on the coolant hose from the radiator. correct?
Mine never started till a little after I replace my Radiator, (Long Story) I am wondering If mine is the actual sensor like I though or the Vic solider Joint.
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
high voltage o2 sensor/bad coolant sensor Jh24k WK Grand Cherokee & XK Commander Forum 1 07-19-2013 10:22 AM
battery temp sensor error sadass ZJ Grand Cherokee Forum 7 07-11-2010 01:49 PM
P0159 error code (o2 sensor) help.... pat29879 ZJ Grand Cherokee Forum 3 06-16-2008 03:58 PM
Output Speed Sensor error ricksuchecki ZJ Grand Cherokee Forum 7 09-04-2007 06:35 PM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 03:52 PM
