2002 GC Overland Build (my turn) - Page 2 - JeepForum.com
 172Likes
post #16 of 498 Old 02-06-2017, 06:40 PM Thread Starter
GhostJeepWJ
GhostJeepWJ's Avatar
Gave him a blood transfusion today and a new liver! Next up is both diffs and transfer. need to order both covers first.
**Side Note - Mileage 175940
maxfederle89 likes this.
It's not the Destination so much as the Journey!! - Cpt. Jack Sparrow
2002 Grand Cherokee Overland 4.7 HO
2" IRO Spring Lift w/Bilstein 5100s 245/75/R17 Goodyear Armour Shield
GhostJeepWJ is offline
post #17 of 498 Old 02-08-2017, 01:27 PM
GreyWj93
Nice build. looking to do a similar set up on my 04 overland however some techs say to lift mine that I need to upgrade my front drive shaft to a double cardan drive shaft, did yours come upgraded since you baught it with the lift?
GreyWj93 is offline
post #18 of 498 Old 02-08-2017, 09:43 PM Thread Starter
GhostJeepWJ
It currently has a 2" IRO Spring lift with Bilsteins 5100s. And if you stay 4/4.5" or less you should be fine. Mine will be getting a Frankenstein lift...lol
Putting an RC 4" Long Arm kit with IRO Springs and new Bilsteins. Sitting on 265/75/17 DuraTracs
Check this thread for a great write up for the swap, courtesy of @ChrisHager
Rezeppa to Double Cardan - IRO Drive Shaft Conversion
post #19 of 498 Old 02-09-2017, 10:05 AM
WJChris
WJChris's Avatar
infinity amp would be under rear passenger seat. The infinity system uses crossovers to only pass low frequencies (bass) to the front door speakers..
WJChris is offline
post #20 of 498 Old 02-09-2017, 02:07 PM Thread Starter
GhostJeepWJ
THANKS!! I was wondering about that! Just haven't taken the time yet to look to see if I had one. That may explain the VERY low output from the front door speakers! Going to go look right now!....lol
Thanks @WJChris
post #21 of 498 Old 02-09-2017, 02:12 PM Thread Starter
GhostJeepWJ
BAM!!! Yep its there! I was first thinking I didn't have one because I had none of the "Infinity" badging on any of the interior parts.
I already bought my Rockford amp. Got any suggestions as to how to fix this little dilemma of the front speakers @WJChris ?
Think I should return the 400w Rockford Amp? Stereo sounds good now and that's without the front door speakers hooked up. Just the dash and the rear door speakers. Android Headunit from Joying is getting dropped in when I rip the dash out to fix the HVAC system.
post #22 of 498 Old 02-09-2017, 03:37 PM
WJChris
WJChris's Avatar
They removed the "infinity" from the speakers starting with 2002 models. As for stereo options and opinions, I cant help much about that, haven't delved into that area much.
WJJEEPS has a plethora of info...
http://wjjeeps.com/jmenu.htm
Stereo specific:
http://wjjeeps.com/audioupgrade.htm
WJChris is offline
post #23 of 498 Old 02-14-2017, 07:10 AM
97Mule
97Mule's Avatar
Nice ride. Just looked over here. I dont have pics of the rust +dirt that came out of my sliders, but it was enough to fill up a large coffee container.
97Mule is offline
post #24 of 498 Old 02-15-2017, 08:52 AM
-HAZARD-
Do you really have a K&N filter in that? I thought they didn't make an element for the 4.7 HO because the airbox is different than the regular 4.7.
04 Overland - 4.7HO - RC 6.5" Long Arm - 33" Pro Comp MT2's -
-HAZARD- is offline
post #25 of 498 Old 02-15-2017, 07:04 PM Thread Starter
GhostJeepWJ
Yes sir! AutoZone had the part number but wasn't in stock. They had to order it. First one that showed up, was wrong. Reordered the correct one, and it dropped right in my box!
post #26 of 498 Old 02-15-2017, 07:14 PM Thread Starter
GhostJeepWJ
Last few pieces to the stereo upgrade arrived today!! Can't wait to get this installed. Suppose to be 65 here on Sunday, so what better way to spend the day!!
Installing the Joying 5.1 Android Unit, Backup camera, Rockford 400w amp, and some spare aux ports! Will post up pics of the install once it's done!! Crossing fingers that everything goes well! It's gonna be a very tight fit with a 7" screen. Cut n Hack and then clean it up!!
JPeppah likes this.
post #27 of 498 Old 02-16-2017, 08:04 AM
99WJ539918
Where did you get the bezel for the radio from? What did the radio cost you?
Build Thread
99WJ539918 is offline
post #28 of 498 Old 02-16-2017, 03:23 PM Thread Starter
GhostJeepWJ
I got both items off Amazon. The Joying unit (after some research) was best one I could find. They also seemed to have the best and quickest CS w/problems or questions. It's also their newest version and has newest 5.1.1 Lollipop OS. Unit was $300 and bezel was $90. The bezel they claimed fits a 180mmx100mm. Unit is 178x100 and doesn't fit, by a slight bit. So I'm gonna have to do some trimming, and I'm sure there's some trimming that will have to be made to the slot in my dash. Cut n Hack....lol. I probably coulda just modified the OEM bezel but I'm gonna use the new one. Here are the links
Radio Bezel
Joying Android Unit 5.1 w/2GB RAM
I also bought steering wheel controls and backup camera. Also, a kit to turn one of my aux ports into a port that has a USB, and an Aux cord.
post #29 of 498 Old 02-26-2017, 07:20 PM Thread Starter
GhostJeepWJ
Finally got around to finishing the passenger side rock rail. Had to cut this one off! Fun!
'But while I was doing that I had the rear tire off. So here ya go @mak_v8
Here's the Amazon link PowerStop Extreme Performance
maxfederle89 and JPeppah like this.
post #30 of 498 Old 02-27-2017, 01:19 AM
mak_v8
Many thanks GhostJeepWJ !
Grand Cherokee WJ 4.7 V8 HO. m.y. 2002
mak_v8 is offline
2002 , custom wj , grand cherokee , lifted wj , overland
