XJ Coolant Bubbling Out of Reservoir Tank? - JeepForum.com
post #1 of 6 Old 05-12-2019, 03:27 PM Thread Starter
mrkevelev
2000 Jeep Cherokee Sport (4.0 L, 4x4). I had my engine idling for about 10 minutes. I then shut it off. About 2 minutes after I turned it off, the coolant began to bubble out of the overflow/reservoir tank. It was fine when the engine was running, and the temperature gauge was sitting right in the middle. I checked all the fluids a few months ago, and haven't had any issues. The only thing that's changed is that the weather has gotten a bit warmer (transitioning from NY winter to spring). Anybody ever seen this before? Also, the thermostat was replaced about 2 years ago, and the coolant level was good. I've been keeping an eye on it periodically since my TUPY head swap last year. So really there haven't been any changes in the last few months.
Thanks!
mrkevelev is offline
post #2 of 6 Old 05-12-2019, 05:46 PM
mukluk
mukluk's Avatar
The first thing that comes to mind would be the radiator cap is old and not holding pressure as it should. Next in line would be you may have some air in the system that needs to be worked out.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 6 Old 05-13-2019, 11:57 AM Thread Starter
mrkevelev
Mukluk,
I don't understand the part about the pressure cap. If it leaked, wouldn't less air be trapped in the system? Isn't it positive pressure inside the radiator? What about the fact that it occurred only after I shut the engine off?
post #4 of 6 Old 05-13-2019, 01:00 PM
mukluk
mukluk's Avatar
Increasing the pressure on the cooling system increases the boiling point of the fluid. Stopping the engine also stops the flow of coolant, allowing areas of coolant in contact with the cylinders to absorb more heat as it just sits there (heat soak). If the radiator cap is weak and providing less than the correct pressure rating, it will allow the fluid in these hot spots to boil, producing bubbles and spitting into the overflow tank.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #5 of 6 Old 05-14-2019, 02:18 PM Thread Starter
mrkevelev
The cap is providing a good seal. I should've mentioned this earlier, but i recently installed a new cap a few months ago (must have forgotten).
post #6 of 6 Old 05-14-2019, 03:09 PM
mukluk
mukluk's Avatar
The spring rating is what's important. Did you install an 18lb cap?
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
boiling , coolant , overflow tank , overheating , temperature
Coolant Overflow Tank fills and "boils" over SixFootStranger ZJ Grand Cherokee Forum 51 08-21-2020 09:55 AM
Coolant Reservoir Sparkybob Jeep CJ Forum 27 07-22-2020 07:34 PM
Mishimoto R&D: 2012-2018 3.6L JK Coolant Filter Kit Mishimoto JK Wrangler Technical Forum 3 01-16-2019 02:32 PM
20 gallon factory poly fuel tank StoneTower Jeep CJ Forum 16 05-16-2018 04:52 PM
Washer Fluid in Coolant Reservoir Arcticcat340 WJ Grand Cherokee Forum 3 04-23-2018 03:07 PM
