Won't start or take a jump, silent, but accessory power works - JeepForum.com
post #1 of 6 Old 02-24-2016, 04:18 PM Thread Starter
Rivka
Rivka's Avatar
'05 LJ that lives a bit of a hard life had what i assumed was a dead battery thing morning after a few weeks of not being used.
Won't take a jump, does not do ANYTHING, no dash light, no nothing, i think i can hear the starter relay or solenoid (single quite click).
i swapped out the starter relay to two other matching ones and nothing changed, the 30A starter fuse near it looks perfect. is there another?
if i turn the key to accessory, the heater and fan turn on just fine and all the cabin and headlights work.
What gives?
I'm already down my DD for the foreseeable future, i can't loose this one too.
"If you don't have time to do it right, you are going to need time to do it over."
'05 Red Flame TJ Rubi UnLtd
"Teach a man how to take his doors off and he will enjoy his Jeep for a day,
teach him to search the forums and he will enjoy his Jeep for life!"
Rivka is offline
post #2 of 6 Old 02-27-2016, 04:01 PM
rjbruzan
Bad battery or real bad connections, Check voltage at battery with a volt meter, should be 12.6 if fully charged. This is the starting point of troubleshooting your troubles.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #3 of 6 Old 02-29-2016, 10:57 PM
KG6KJS
KG6KJS's Avatar
What gives?
Check the ignition switch actuator pin. DORMAN 924-704
If it is broken at all, the Jeep will not start. You might hear the relay behind the glove box and that's it.
2006 Jeep LJ "Fred"
KG6KJS is offline
post #4 of 6 Old 03-06-2016, 04:52 PM
Tru2Chevy
Tru2Chevy's Avatar
1992 XJ Cherokee
Could just be a dead starter....have it tested.
- Justin
1992 Cherokee Laredo - mostly stock, DD. 300k miles and counting
2004 Grand Cherokee Laredo - 4.7, bone stock - Wife's DD
Tru2Chevy is offline
post #5 of 6 Old 03-12-2016, 01:33 PM
PhulesAu
Putting money on ignition switch.
PhulesAu is offline
post #6 of 6 Old 03-12-2016, 03:20 PM
LumpyGrits
Lets go with KISS.......
Switch out the battery with a KNOWN good starter battery.
FI engines need lots of AMPS to fire up.........
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
