What sealant to use on a leaking #11 head bolt? - JeepForum.com
post #1 of 4 Old 08-22-2016, 05:20 AM Thread Starter
CarComp
I have my whole engine assembled for awhile now. I have been tracing down a pretty substantial coolant leak. I replaced the radiator (it needed to be replaced, it was full of crud), and bypassed the heater core. I have found that the leak looks like its coming front the head gasket near the #11 (i think) head bolt... The one that goes into the coolant jacket. I probably didn't use enough goop / the wrong goop / forgot to goop / reused the goop. Who knows. But now its full of coolant, and i need to pop it out and seal the thing, and put it back in.
What kind of sealant should I use? I'd rather not drain the coolant out of it again, but I will if I must. I'd rather use a putty type sealant, or a 'mechanical' sealant that works by displacing the water (like silicone) and then its just stuck in there and hardens. I have regular white 'thin' thread sealant and I also have some RTV black. I will purchase something else.
I don't wanna get into the argument about reusing the head bolts. I already found out that its fine to reuse them. Also I am not tearing it down again to fix it. If i can't seal it up, its just gonna leak. This would make 4 times having the head off if I were to dismantle it.
CarComp is offline
post #2 of 4 Old 10-24-2021, 11:51 PM
AZSobo
Location: Somewhere in the desert west of New Mexico and east of California.
I have the same question, have possible leak @ #11.
I want to put a new bolt into #11 - coolant system full, don't want to drain, which sealant for this application, would Permatex High Temp be a good choice?
2001 Jeep Wrangler Sport, 4.0L, 30x9.5 15 Tires on Alum. Rims, Tomken Bumpers front and rear - Everything else Stock
AZSobo is offline
post #3 of 4 Old 11-25-2021, 09:49 PM
Boojo35
1987 YJ Wrangler
Permatex thread sealant. It is a liquid type teflon sealant made specifically for threads.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #4 of 4 Old 11-26-2021, 06:49 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Permatex aviation form a gasket
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
