water pump - JeepForum.com
post #1 of 5 Old 03-31-2020, 05:50 PM Thread Starter
hawaiian808
water pump
wats up guys!
Had a question about the water pump. would the blades still spin if the bearings went out?
hawaiian808 is offline
post #2 of 5 Old 03-31-2020, 06:43 PM Thread Starter
hawaiian808
this is after you take it out of the jeep, when you spin the front would the blades still spin is my question if the bearings went bad?
post #3 of 5 Old 03-31-2020, 09:07 PM
mukluk
mukluk's Avatar
Provided the bearing isn't seized, yes, the impellor would still spin. The mere fact the impellor spins doesn't necessarily mean the bearing is still good however.
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #4 of 5 Old 04-01-2020, 07:18 AM Thread Starter
hawaiian808
Okay, I took it out because I did a coolant flush and change thermostat, hot air wasn’t coming out of heater. And the day after I fixed it I started it up and I made that mild squeal, so when I took the water pump out and spun the front and the blades still spun, got me thinking that I took it out for no reason, or maybe I tightened the S belt on too tight?
But the fact that the blades would still spin even if the bearing are bad makes me feel a little better pulling everything out!
post #5 of 5 Old 04-01-2020, 01:42 PM
mukluk
mukluk's Avatar
Quite often a squeal after doing cooling system maintenance is from coolant that has gotten on the belt and/or pullies. If the squeal doesn't stop after the first few seconds of running, try rinsing the belt and pullies with water and check your belt tension to make sure it's not too loose.
2000 TJ SE
2005 LJ Rubicon
