Using gear oil with LS additive - JeepForum.com
post #1 of 7 Old 10-18-2020, 12:26 PM Thread Starter
JASJ
My understand is that my 2012 Rubicon does not need this additive like other models do with trac loc. Stupidly I realize now I accidentally ordered it with the additive. Is this an issue, having the additive?
JASJ is offline
post #2 of 7 Old 10-18-2020, 12:34 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
No, it will be OK.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #3 of 7 Old 10-18-2020, 12:43 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Not a problem. Most of the synthetic gear lubes you buy will have it in there anyways. All the additive does is keep the clutches in the LS diff from chattering.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 7 Old 10-18-2020, 01:00 PM
Tarneg
if they dont need it and you add it nothing will break but you will probably lose strength of the clutches as they will slip easier
Tarneg is offline
post #5 of 7 Old 10-18-2020, 01:03 PM Thread Starter
JASJ
but if it’s a mechanical lock in my rubicon it doesnt have clutches, right?
JASJ is offline
post #6 of 7 Old 10-18-2020, 01:16 PM
Tarneg
ah yes correct if its all mechanical engagement then it wont care if its the same weight oil
Tarneg is offline
post #7 of 7 Old 10-18-2020, 02:20 PM
222Doc
222Doc's Avatar
The additive cost more, you do not need it wont hurt nothing. I have only used dino oil on both d44s on our JKr, its cheap and they do not need syn in my opinion. The additive i use on my one tons is not cheap. Would not waist it on a rubicon locker. Since the Jkr has drain plugs front and rear its a simple job really.
222Doc is offline
