transmission hunting - JeepForum.com
post #1 of 5 Old 07-03-2020, 01:14 PM Thread Starter
Rldsl
I've got a 97 zj , 4.0 < 200k . Transmission has started hunting in and out of overdrive at the slightest incline. Fluid is all relatively fresh( its has a small pan gasket leak:-) filter not sure the age, but it was replaced at least once in its life. Where would be a good place to start looking in this one ? Thanks.
Rldsl is offline
post #2 of 5 Old 07-03-2020, 03:56 PM
jtec
jtec's Avatar
2014 JK Wrangler
thoughts -
Brake light switch.
TPS.
jtec is online now
post #3 of 5 Old 07-04-2020, 12:22 AM Thread Starter
Rldsl
Originally Posted by jtec View Post
thoughts -
Brake light switch.
TPS.
interesting. TPS is fresh within a month. But brake light switch is one I certainly wouldn't have considered.
Rldsl is offline
post #4 of 5 Old 07-04-2020, 07:33 AM
jtec
jtec's Avatar
2014 JK Wrangler
why did you change TPS? might be a clue.
jtec is online now
post #5 of 5 Old 07-04-2020, 04:49 PM Thread Starter
Rldsl
it was having some idle issues lacking any codes. I started replacing. It has new TPS, IAC, CPS, O2 sensors, distributor sensor and ignition coil. Along with fresh plugs, wires, cap and rotor. The temp sensor was fresh right before I got the thing about 5 months ago, connection on it might be questionable. Other than that it was well maintained by previous owner.
Rldsl is offline
