Transfer Case won't engage into 4WD - JeepForum.com
post #1 of 2 Old 05-15-2019, 05:56 PM Thread Starter
tuekwik
My 72 J2000 won't engage into 4WD. The shifting lever moves pretty much freely. It won't go into 4HI or 4LO. From the info I gathered it seems to be a Dana 20. Truck has a 360 and TH400 tranny. Any help would be appreciated. Thanks
tuekwik is offline
post #2 of 2 Old 05-23-2019, 12:59 PM
Jepe
If it is really moving freely, it is possible that the linkage has simply come loose. If you crawl under the vehicle and check the adjustment point under the shifter itself, you can pull on the shifter lever and see if it just slips along the linkage. If that is solid then it is something in the transfer case itself.
Jepe is offline
Higher Output Alternator tjohnathon ZJ Grand Cherokee Forum 25 01-14-2020 03:21 PM
transfer case 4wd switch over during acceleration pawntan WK2 Grand Cherokee Forum 40 05-10-2019 04:32 AM
How To: Clock Your Transfer Case miteofthesun XJ Cherokee Technical Forum 0 06-08-2018 10:41 PM
What is a CV shaft and why do I want one? Unlimited04 TJ Wrangler Technical Forum 175 02-23-2018 10:17 PM
Transfer Case Linkage & 4WD Jesse561 TJ Wrangler Technical Forum 3 12-04-2017 02:33 PM
