Transfer case drop - JeepForum.com
post #1 of 4 Old 07-28-2010, 02:42 PM Thread Starter
schultr1
Transfer case drop
So i am looking at getting a 4" RC suspension lift for my 2003 TJ and using the transfer case drop kit that comes with it. but i was wondering when i put the kit in will my gear shift and 4wd shifter drop too?
This may be a newbie question but i was just wondering if there is a way to keep them at stock height or if the kit will come with it
schultr1 is offline
post #2 of 4 Old 07-28-2010, 05:11 PM
AFjeepMan
AFjeepMan's Avatar
there is a very easy correction for the t-case shift linkage that is outlined in the instructions, and I am pretty sure that issues, if any, with the transmission shifter will be addressed by them as well...call Jeffery at RC and ask him quickly.
2005 Wrangler TJ, 3 1/4" RC lift, Cragar Soft 8's 32" BFG Mud Terrains, Smittybilt SRC D-Ring bumpers, Smittybilt XRC8 winch, Body Armor Rockcrawler side guards
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
Relearn your priorities.
WANTED: SYE and cv shaft...good condition and good price. for a TJ with about 5-6" of lift.
AFjeepMan is offline
post #3 of 4 Old 07-29-2010, 08:46 AM Thread Starter
schultr1
well i was wondering if i could do a MML and by pass doing the T-case drop and avoid and shifter issues at all or will that not work? I really don't want my shifter any closer to the floor
schultr1 is offline
post #4 of 4 Old 07-29-2010, 01:13 PM
AFjeepMan
AFjeepMan's Avatar
well you will run into a little bit of the same issue when you put the bl of for the mml. unless you don't do a bl and just trim the fan shroud. it's really easy to adjust the t-case shift linkage, you just have to loosen the set screw and the handle link will just slide on the t-case link.
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
t-case drop , shifter , transfer case
is there a need for a transfer case drop kit? bloodwood70 Tires & Wheels 1 02-24-2008 07:21 AM
Transfer Case Drop YJBlues Tires & Wheels 2 06-27-2006 06:19 PM
OME transfer case drop MCKray Tires & Wheels 1 04-22-2005 04:29 PM
Do I need to drop the transfer case with SYE moabster Tires & Wheels 5 06-25-2002 09:37 PM
HELP! Transfer case drop ID ArmyYJ Tires & Wheels 7 04-06-2002 09:21 PM
