Testing Crank Position Sensor - Page 2 - JeepForum.com
 1Likes
post #16 of 16 Old 07-04-2021, 06:03 AM
V8GCZJ
To be clear, it cranks, no start. I checked the ASD relay for functionality, but not the signal coming or going. the relay checks out.
We still don't know where your issue is in the lac of spark or fuel. Check for spark: Pull one of the coil packs and put a spark plug on the end then place it on an engine ground. Have somebody crank the motor and see if you have spark. You need signals from both crank and cam sensors BEFORE the pcm can fire the coil packs. Pics really aren't going to help us any in determining where you issue is.
V8GCZJ is offline
