Stuck Lower Ball Joint - JeepForum.com
post #1 of 8 Old 10-08-2021, 07:31 PM Thread Starter
salesrep01
Have a 2013 Wrangler Sahara. Replacing ball joints (and axle bearings) to get rid of the death wobble. On passenger side, upper ball joint came out with some convincing. Lower ball joint is a different result (seems to be not uncommon). Have used Autozone loaner ball joint press (bought pipes sized so the lower ball joint will drop through), tightened with breaker handle and 3' pipe extension. Won't budge. Put Break 'R Loose on for overnight. Still nothing. More pressure, nope. Beat with a small sledge while pressure is on, nope. Tried propane torch heat for 2 minutes, bang on yoke with short sledge, no movement. Thinking of trying 4-ton hydraulic bottle jack, which will fit within the yoke; will put a large nut underneath the jack so it pushes the joint through (plate under jack so nut doesn't damage the jack body, will also require a plate for the upper ball joint hole). Will pressure damage the wheel yoke? Can Jack be inverted so the piston ram pushes on the ball joint? 4 tons enough (willing to buy 8 or 12 ton, $30-$35 at Harbor Freight)?
salesrep01 is offline
post #2 of 8 Old 10-08-2021, 10:26 PM
80cj
80cj's Avatar
1980 CJ5
Make sure you're pushing the ball joint in the correct direction. Is there a retaining ring holding the BJ in place?
80cj is offline
post #3 of 8 Old 10-08-2021, 10:38 PM
80cj
80cj's Avatar
1980 CJ5
This guy makes it look easy
80cj is offline
post #4 of 8 Old 10-09-2021, 12:05 AM Thread Starter
salesrep01
I followed the same youtube video. See pics (old yoke showing old BJ, and new ball joint w/grease fitting); no retaining clip. My concern with using a hydraulic jack is it will use the upper arm of the yoke as the resistance for pushing against the one I want to remove. Will it take that much pressure (a regular ball joint press is 20 tons; I'm considering a HF 12 ton). Sorry, it's late, I couldn't figure out how to resize.
990194FE-C7DC-42CB-908B-CBD72A8F3BE3.jpg   DE9579B7-44A5-4DA6-9ABC-F3778ECCEEF4_1_105_c.jpg
post #5 of 8 Old 10-10-2021, 07:13 PM
80cj
80cj's Avatar
1980 CJ5
Try a propane torch on the outer areas surround the ball joint.
80cj is offline
post #6 of 8 Old 10-11-2021, 10:33 AM
222Doc
222Doc's Avatar
assuming you have a good C press, like the one in the video. When you have it at high torque and it dont move i use a 2 pound brass hammer. and smack the c. Since it is brass you can hit it as hard as you like. seems to always pop loose. if that dont work>heat and hammer keep the torque on the clamp but dont bend it if you can, some low end ones can bend.
my 12 the lowers had to use the the hammer and i have a good C clamp.
222Doc is offline
post #7 of 8 Old 10-17-2021, 02:33 PM Thread Starter
salesrep01
So I finally got the ball joint to budge. The sweetest sound is the "bang" it gives off when it moves. Don't know if it's because I greased the thread on ball joint tool (Autozone loaner, like a big C-clamp) or because I put a socket on the top of the joint so all the pressure was on the outside edge (see picture above). When I got it out, there is a ridge like would be there if there was a retaining clip. If you look at the picture above from the top of the joint, the ridge would have been below the top of the hole - there is no clip evident. Anyone ever seen a retaining clip? I'm proceeding with the other side like there is no clip.
post #8 of 8 Old 10-17-2021, 03:51 PM
80cj
80cj's Avatar
1980 CJ5
Glad you got it out. CJ's use a ball joint with a snap ring groove but the snap ring is not used. The ball joint is probably used for other applications that may use a snap ring. Probably same situation with yours.
80cj is offline
ball joint , hydraulic , stuck , torch , yoke
