stroke/rebuild a 4.0L please contribute your knowledge and advice - JeepForum.com
post #1 of 6 Old 08-23-2011, 08:45 PM Thread Starter
DoctorTim
DoctorTim's Avatar
So my 1996 4.0L is going in for a rebuild sometime soon due to a knocking noise and bad exhaust valves
My father said he would pay for it.
What I would like to do is to stroke the 4.0, but that costs a big chunk of money and he said no to the part where it costs a lot. I need to find a way to increase the stroke of my motor for as cheap as possible. I don't care how much more liters my motor gets, anything helps, im serious, even if it gets it to 4.1L
Informational websites about stroked motors are way too lengthy and technical for me to understand.
DoctorTim is offline
post #2 of 6 Old 08-23-2011, 09:51 PM
JeepinJarhead03
do it right, do it once
if money is an issue, it may be better off for you in the short, and long run, to see if you can find a 4.0 that's not knocking and still runs pretty well that someone doesn't want / or cheap , IE the for sale section here
Heck, even a running 4cyl might get you by while you save up money and get parts as you're able to afford it
ya need to decide if you can afford to get the block milled and cleaned up for the new build before going down that road, it can be cheap to fix mechanical problems, but not prepping your block correctly on a new build is a great way to drain your investment out your oil pan in 10k miles
JeepinJarhead03 is offline
post #3 of 6 Old 08-23-2011, 09:52 PM
flatlander757
flatlander757's Avatar
Then obviously anybody with information to contribute is wasting their time replying to you.
http://www.lmgtfy.com/?q=jeep+4.0l+stroker
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #4 of 6 Old 08-27-2011, 12:10 PM
herbiehind
jeep strokers.com
herbiehind is offline
post #5 of 6 Old 08-27-2011, 12:22 PM
gremlinsteve
gremlinsteve's Avatar
yep..jeep strokers.com has a low buck recipe. no rewason to rebuild the stock 4.0 stock again..
except tuning....you will not have any luck there in my opinion. i do not like piggy backs and you have nothing else available.
ill put my two cents in for a stock rebuild to keep you going since you are obviously money strapped.
steve-o
gremlinsteve is offline
post #6 of 6 Old 08-27-2011, 12:28 PM
herbiehind
dino svvys' adjustable map sensor .
TH400 general advice on rebuild Blue Mule Engines & Drivetrain 0 09-08-2010 12:40 PM
I want to stroke 4L. Need advice please. CB3 Engines & Drivetrain 25 02-16-2009 02:28 PM
NP231 Rebuild Problems - Need Advice mtdg311 Engines & Drivetrain 0 12-26-2008 02:59 PM
AMC 360 V8 rebuild advice a2d3a2m6 Engines & Drivetrain 4 06-09-2008 08:02 AM
Need parts advice/good website to buy from for rebuild.... djaychris Engines & Drivetrain 5 08-11-2006 04:46 PM
