So I got my jeep one year ago and she’s ran great till now. I was having issues with it running a little hot so I flushed the radiator and washed it off and it’s running better and have a new radiator on order. Since she’s a RHD, everything has to be ordered, lol. I am getting a LOT of heat from floor and she has thrown transmission codes. Transmission is running fine but could it be getting hot? And what can I do to help cool it?
Super tech is the house brand oil and filters you find at Walmart. The Jeep 4.0L engine is a PowerTech, though rarely does anybody call it that -- almost universally it's just known as the 4.0L engine. Since your Jeep is kicking out automatic transmission fault codes, it's likely safe to assume you have the auto, which for a 2005 model would be the 42RLE transmission.
P0463-FUEL LEVEL SENSOR NO.1 HIGH
When Monitored: Ignition on and battery voltage above 10.4 volts.
Set Condition: The fuel level sensor signal voltage at the PCM goes above 4.9 volts for
more than 90 seconds
POSSIBLE CAUSES:
FUEL LEVEL SENSOR VOLTAGE ABOVE 4.9 VOLTS
FUEL LEVEL SENSOR
(N4) FUEL LEVEL SIGNAL CIRCUIT SHORTED TO BATTERY VOLTAGE
(N4) FUEL LEVEL SIGNAL CIRCUIT OPEN
(K900) SENSOR GROUND CIRCUIT OPEN
PCM
P0700 is a generic fault saying that you have at least one P07xx series fault that has set
P0732-GEAR RATIO ERROR IN 2ND
When Monitored: The Transmission Gear Ratio is monitored continuously while the
Transmission is in Gear.
Set Condition: If the ratio of the input RPM to the output RPM does not match the
current Gear Ratio.
POSSIBLE CAUSES:
RELATED DTC’S PRESENT
RELATED PRESSURE SWITCH DTC’S PRESENT
INTERMITTENT GEAR RATIO ERRORS
TRANSMISSION - INTERNAL
P0733-GEAR RATIO ERROR IN 3RD
current Gear Ratio.
POSSIBLE CAUSES:
TRANSMISSION SOLENOID PRESSURE SWITCH ASSEMBLY
INTERNAL TRANSMISSION
P0734-GEAR RATIO ERROR IN 4TH
current Gear Ratio.
POSSIBLE CAUSES:
P0846-2/4 PRESSURE SWITCH SENSE CIRCUIT
When Monitored: Whenever the engine is running.
Set Condition: The appropriate DTC is set if one of the Pressure Switches are open or
closed at the wrong time in a given gear .
POSSIBLE CAUSES:
TRANSMISSION RELAY DTC’S PRESENT
TRANSMISSION CONTROL RELAY OUTPUT CIRCUIT OPEN
2/4 PRESSURE SWITCH SENSE CIRCUIT OPEN
2/4 PRESSURE SWITCH SENSE CIRCUIT SHORT TO GROUND
2/4 PRESSURE SWITCH SENSE CIRCUIT SHORT TO VOLTAGE
2/4 PRESSURE SWITCH
TRANSMISSION CONTROL MODULE
INTERMITTENT WIRING AND CONNECTORS
P0871-OD PRESSURE SWITCH SENSE CIRCUIT
closed at the wrong time in a given gear.
POSSIBLE CAUSES:
TRANSMISSION CONTROL RELAY DTCS PRESENT
O/D PRESSURE SWITCH SENSE CIRCUIT OPEN
O/D PRESSURE SWITCH SENSE CIRCUIT SHORT TO GROUND
O/D PRESSURE SWITCH SENSE CIRCUIT SHORT TO VOLTAGE
O/D PRESSURE SWITCH
P1775-SOLENOID SWITCH VALVE LATCHED IN TCC POSITION
When Monitored: During an attempted shift into 1st gear.
Set Condition: This DTC is set if three unsuccessful attempts are made to shift into 1st
gear in one given ignition start.
POSSIBLE CAUSES:
RELATED DTC P0841 PRESENT
L/R PRESSURE SWITCH
L/R PRESSURE SWITCH SENSE CIRCUIT OPEN
L/R PRESSURE SWITCH SENSE CIRCUIT SHORT TO GROUND
L/R PRESSURE SWITCH SENSE CIRCUIT SHORT TO VOLTAGE
Related Threads
Jeep Enthusiast Forums
18.5M posts
727.5K members
Since 2000
