ring & pinion pattern check pictures - JeepForum.com
post #1 of 6 Old 12-03-2007, 09:44 AM Thread Starter
sportcoupe
2017 WK
I just set up new gears on my 8.8 rear for the TJ and since it's only the second set of gears I've ever set up I'd like someone more experianced look at my pattern pictures. The pictures I left full size (2848x2134) so I posted a link to them.
I set backlash at 0.010" and my runout is 0.001". My pinion preload is 25 in lbs. with all new bearings.
Coast side picture
http://www.blackgto.com/jeep/coast.jpg
Drive side picture
http://www.blackgto.com/jeep/drive.jpg
sportcoupe is offline
post #2 of 6 Old 12-03-2007, 11:26 AM
notmyj
notmyj's Avatar
Your pinion preload is tight. Should be 14-19 in/lb. Backlash is bit tight as well it should be .011-.016"
The patern has good contact, but personally I would move the pinion back a bit (away from the ring gear) and adjust the stuff mentioned above.
Check here for tips. http://www.ringpinion.com/Content/Ho...lation_Kit.pdf
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #3 of 6 Old 12-03-2007, 11:43 AM Thread Starter
sportcoupe
2017 WK
Ford spec on the 8.8 is 16-29 in lbs for pinion preload and .008-.015" for backlash. That is why I set mine as such. Still think it's tight?
post #4 of 6 Old 12-03-2007, 02:31 PM
Nonya
25 inch lbs is fine with new bearings....backlash 5-8 range if anyone tells you otherwise move on
Nonya is offline
post #5 of 6 Old 12-04-2007, 08:37 AM Thread Starter
sportcoupe
2017 WK
So you're saying that the Ford spec for backlash is wrong?
post #6 of 6 Old 12-04-2007, 08:51 AM
87Xota
Guest
I've heard a couple different theories about backlash, some builders feel if the spec. for instance is .006 to .010, they try and get the setting as close as possible to .006 and they feel as the gears wear, the backlash will open up a little. And many builders feel regardless of factory spec's, .006 is enough backlash to allow lubrication to get between the teeth as they mesh together.
I haven't found that to happen, in gears that i've checked after they've been ran for awhile, the backlash seems to stay the same. I like at least .007 and have no problem going to the max of whatever the gear manufacturer specs are.
But i'm sure if you ask 5 different succesfull builders, you'll get 3 different answers.
87Xota is offline
used ring and pinion shotgunsmith Engines & Drivetrain 3 12-30-2008 08:30 AM
D44 Ring and Pinion Jeds Sr. Engines & Drivetrain 3 10-16-2008 02:20 PM
Which ring and pinion? harley2003rkc Engines & Drivetrain 4 09-29-2008 07:42 PM
Ring and Pinion NeBlue93Yj Engines & Drivetrain 2 04-16-2008 09:36 PM
Ring and Pinion TnTRacing28 Engines & Drivetrain 10 04-12-2007 04:35 PM
